first time using a VIA mobo...4 in 1??
murphy55d
11,542
Just got a KT266A board up and running, I installed the 4in1 off the SOltek driver disk, do I need to find updated ones now? What are the best ones?
I also heard that running XP, you don't really need the 4 in 1s, as XP has native support. Is this true?
RedRooster
6,596
Good question, as I'd like to know as well. Not only the 4-in-1's, but also, does installing the Promise controller, USB2.0, or onboard sound/nic drivers provide any advantage over using whatever WinXP can install on its own?
Mem
21,476
13
You don`t have to install the drivers with WinXP since it has native VIA support,however the latest VIA 4 in 1 drivers(4.38) are newer and the new AGP driver in there does give you a small performance boost in XP,I installed them with no problems, still rock stable.It`s really up to you if you do or don`t,personally I`ve never had any problems with any of the VIA 4 in 1 drivers .
