I have had many Corsairs and never had one fail....
http://www.newegg.com/Product/Produc...82E16817139020
http://www.newegg.com/Product/Produc...82E16817151094
Have you personally used the Corsair TX 650W V2 for over a year and not had it fail?
yes I have had probably a dozen Corsair PS's over the years from 430 to 850 watt ones and never had any issues... now that isn't to say some are going to be bad of course there will always be that probability
I am just saying Corsair is a good reliable brand and Seasonic makes the for them. My next PS will probably be Seasonic as may as well buy straight from them vs. Corsair... unless the price is more than it's game on for which one is cheaper
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story9&reid=216
http://www.newegg.com/Product/Produc...82E16817207015
Looks good, not sure on noise as I never used one, but should be fine. 5yr warranty is nice, and mono rail is a must.
BTW do not get the EVGA get either Gigabyte, MSI, or ASUS you will be sorry with how dam noisy and HOT the EVGA runs vs. the other 3...
Let us know how it goes! :thumbsup:
wow, shipping is expensive, that's like another mobo right there. Looks like a nice build, please report back!
Ah that is why I hate laptops they are junk PC's as they can't take the heat and if they don't have heat they are not good for much as they are to underpowered.... I wouldn't spend more than $400 on a laptop anymore after having so many cook or fail over the last few years... Desktop's are king IMO and only reason to own a laptop IMO is you HAVE to travel a lot. Then yes you have no option, but again unless I am on the go all the time, no I will always own a desktop!
Incidentally, the new system has been shipped by DHL. Hopefully should be here in a couple of days?
Maybe. Most likely it will get kicked around at bit and lost for a few days first though. D:
(the yellow device is an infrared thermometer measuring the temperature of the outside of the oven's glass casing. The silver thing is of course the foil pouch with the laptop's graphics card inside...)
FYI, a transparent surface like glass will not give you an accurate reading with an infrared thermometer. This is because infrared thermometers do not directly measure temperature, instead they measure the infrared emissivity of an object. This is generally correlated with temperature of course, but there is at least one coefficient in the formula that depends on the material type. Infrared thermometers are typically calibrated for matte metal surfaces.
Still, at room temperature the IR thermometer is surprisingly accurate - I frequently shoot it at the bulb of a glass thermometer hung on my wall (I use it for room temperature measurement) and the reading matches to within 1 degree C of what the glass thermometer says. Though since everything is at room temp and it's a small bulb, the IR might be influenced by the matte painted wall behind and around the glass.
Incidentally, according to boincstats, it is now the most powerful BOINC computer in all of Malta, at least based on points per hour of runtime 😎 - though 95% of the points come from the GPU...
