Originally posted by: keysplayr2003
Kind of like the Pentium 4. It didn't start to get ANY kind of good until the 1.8GHz mark.
I dunno why the whole 'things take off at # GHz' that Gary posted. To me that's only worth saying if it scales beyond what is normal so a 10% bump in frequency from 2.4GHz to 2.64GHz somehow gave it a 15% performance gain. To me that would be 'taking off' at some frequency.
If on the other hand like the P4 example, if he just said "It becomes competitive at 2.4GHz" then it all makes sense just as how the P4 was a non-competitive product at frequencies below 1.8GHz.
Originally posted by: cmrmrc
How the hell did he get Opteron 2332?....last i checked AMD is launching the 2.0ghz as 2350...
I doubt those are fake benches, but the performance of the retail part isn't going to be as bad as they indicate. Nor do I believe they are going to be as good as the INQ story about 30k 3dMark06.Originally posted by: Viditor
Agreed...it seems to me that either the benches were done on a very old Barcelona chip, or they have been faked.
I still don't see why it says both Opteron 2332 and Agena on the chip as they are very different except at the basic core level.
1. Barcelona is HT 2.0, Agena is HT 3.0...
2. Barcelona is socket 1207 and multiprocesser, Agena is socket AM2+ and uniprocesser
Originally posted by: Amaroque
'takes off' is subject to interpretations. I think he meant it that way, because AT is under NDA rite now.
As far a scaling, the A64 scaled something like 1.5 to 1 as compared to the P4. Meaning that for a 100 MHz bump on both processors, the A64 would see something like 50% more performance increase over the P4.
yep, in fact, without other variables (higher FSB, etc) there's no logical way that an increase more than 1:1 of performance v clockspeed is even possible, with the same core.
The increases in P4 performance were due to improvements in the architecture, not magic 1.0/1.1+ mhz/performance returns upon clock speed increase. The P4, over it's lifespan, went from a measly 400fsb/256k L2, to 533 and 800fsb, and 512k and 1m L2 caches, and newer SSE capabilities, and hyperthreading.
Anyways, a P4 Willamette core, from 1.3ghz to 2.0ghz, never showed a rising performance curve vs core speed. Though it did become faster than the Athlon XPs at the time (1600+) by reaching the 1.8Ghz clock speed. The Northwood revision was the real shot-in-the-arm that Intel needed, and I do believe that the extra L2 cache and higher FSB account for the drastic performance uptake we saw at the time. It'd take some digging in old articles, but if someone thinks that an excess of a 1:1 improvement can be found in clock frequency alone, without touching ram/fsb access at all, I'd like to hear it.
that sounds right. I'm at 14.281 at 3.512Originally posted by: Idontcare
They report a 2GHz K10 does 1M SPi in 39.657s...
Hmmm I think thats kinda slow.
I think so too. Here's a comparison of 3.6GHz overclocked Conroe's, they tend to come in around 13.9s for 1M. Not the best comparison, but you can clearly see the K10 is not likely to best a Conroe (or Penryn) by 40% in this benchmark if the one posted on coolaler.com is representative of K10 (always questionable when there are zero statistics).
Gary are you saying that the part scales better than linear? Interesting...
Originally posted by: SickBeast
Gary Key: Thanks very much for the information.
Seeing as the AT staff don't even have the lastest Barcelona cores, then I've gotta call shens on all of these 'preliminary benchmarks'.
Not exactly, I cannot go into the details yet, just imagine the cache/memory pipeline as being a supercharger on a car, you have an engine (same compression ratio/cubic inches for NA versus SC) that performs the same until you hit a certain RPM/air-fuel mixture where the SC comes online and the power curve changes dramatically compared to the NA engine. The same basis is occurring here, all of the changes/enhancements made to the core / HT/ cache / memory controller are basically "idle" in some cases (SC is flowing more air than than the engine can take advantage of at low RPM plus you have parasitic drag from powering the SC), if not a hindrance (low compression and mismatched gearing). An engine (CPU) is most efficient at its torque peak (wherever that happens to be based on gearing, displacement, compression, efficiency, etc) and in this case, it starts nearing it (torque peak) around 2.4GHz from all indications.
This is a very crude and simple example but about the only way I can state information at this time. The simple fact is, this core needs clock speed and until 2.4GHz or so, it is not that impressive in my opinion on the desktop. Certain transactions/operations will be noticeable/improved over some of the Core 2 family processors on a performance/wattage aspect from an enterprise overview, but this chip design is going to require clock speed before you start seeing some numbers that make sense in the consumer/workstation market. That is why Phenom will launch at higher clock speeds, different core configurations, and with chipsets designed to take full advantage of the core changes with consumer applications. That is my guesstimate based on performance up to this point, several of the larger OEMs received their final silicon chips this past week, most noticed another improvement in performance, how much, we will find out shortly but do not expect a leap frog over the Blue Bunnies yet.
I would not be surprised to even see supply shortages until early next year and still think BullDozer is the AMD CPU that will make or break the company. Barcelona and Shanghai, plus their desktop counterparts, are evolutionary designs (core basis) based off the K7/K8. This is why I have never really understood the hype around this launch, yes, performance improvements will come and we get some interesting new technologies like HT 3.0 /native quad core layout, but without clock speed improvements to match, you end up with A64 X4+ for a lack of simpler words.
AMD stated there was 90% tweaking of the core and well, I wouldn't consider that as minor by any means
Jason
I assume you're referring to the SuperPi score, seeing as you already called 'shens' on the 3DMark '06 score of 30,000.Originally posted by: Gary Key
Actually, based on the last chip we had, those numbers are in alignment with some of the results we noticed and others as well. I think they will be better than that at release and especially on a consumer board with Vista 64-bit. Until we have final silicon and boards, anything is a guesstimate at this time. I just think people are going to be disappointed in some ways, as were we, until the clock speeds come up.
Originally posted by: dmens
Except a CPU has static resources, whereas a car engine can burn more fuel because a supercharger fed it compressed air. CPU core frequency increases cannot never yield greater than a linear performance gain.
That is certainly not true today, when cpus have so many other factors that conincide with cpu frequency. Such as multiple cores, HT, integrated memory controllers, enhanced buffers, enhanced branch chain prediction and the etc. So cpu frequency in general in todays cpus is not the dominant factor that it once was.
If the L2/L3 cache runs at twice the speed of the core, then I can see this happening. At 2GHz, a Barcelona's cache runs at 4GHz (hypothetically). Pump up the core speed to 2.6 GHz and the cache will be at 5.2GHz. So with only a 600MHz core increase, the cache speed increased 1200MHz.
The Pentium 4 did this, but after cranking up the clocks so high, diminishing returns were experienced. Wall was hit.
I'm not saying Barcelona will be this way, but it could explain the "power band" of the processor above 2.4GHz.
