WhoBeDaPlaya
I see this becoming a meme in a matter of weeks 😀
And thats exactly what i would like to know, if the CPU will grand me any gains at the resolution I and most of the people play and thats at 1080p. Bench the games at 720p but also show us if we will get any gains at 1080p as well(obviously not with low settings).
Would you consider upgrading a CPU+Motherboard if you would know that you will only gain a 2% at 1080p ??
Most people aren't as much bothered with it. I have friends who dont give a damn about these things, as long as their games run well. Sometimes you do get a feeling that you need above average close to most expensive gear to play games. That's of course not always the case.I see your point.
It's why I find most reviews to never really give me the information I need. But then again, you might as well ask them to test every single combination out there. It's a hard life haha.
That's why it says "up to". Pretty much how the supposed FX scheduler hotfix was "up to 10%" but proved to be 0.5% all around ()🙂. Except in this case the all around benefits will be around 25% 😉
What are your machine specs again?
There is no "up to" in the poster whom I was replying. Good that you mention the FX hotfixes. They provided up to 10% performance gain in some game, 5% in several games, 2% in some...
Average gain depends of the applications selected, but 2-5% gain is normal. This is far from the average 1-5% gaming gain provided by Haswell over Ivy.
http://www.chinadiy.com.cn/html/42/n-9142-3.html
Hopefully that is not reflective of performance. 1.45V for 4.8Ghz and it hits 100C temps.
Stock cooler.
mmm...stable 175MHz BCLK looks yummy!
Is the BCLK on the K models unlocked in 1Mhz increments, or does that depend on the mobo? Can you OC with BCLK on non-K models?
That's the million dollar question. If the 4770 can do BCLK (straps/increments), I'm getting it instead of the 4770K. Nothing like saving some $$$ _and_ getting a superior CPU (+ TSX)Is the BCLK on the K models unlocked in 1Mhz increments, or does that depend on the mobo? Can you OC with BCLK on non-K models?
For 8150
Average over windows auto updates is ..... -1%. Windows 8 is slightly ahead and more efficient. But overall it looks like the hotfixes were a step backwards.
The last time we looked at the impact of Microsoft's hotfixes was almost a year ago. In today's comparison, our baseline Windows 7 machine is loaded with a lot more patches from Windows Update, and they cumulatively seem to have a larger impact than the two manually-installed tweaks specific to AMD's Bulldozer architecture. In fact, overall performance is better without the hotfixes applied.
They are comparing Windows 7 plus hotfixes installed manually to Windows 7 with auto-updates:
Either the auto-updates include improved versions of the hotfixes or include some other improvement on the W7 scheduler. That is why there is a 1% improvement over Windows 7 with the hotfixes installed manually. Windows 8 includes improvements on the scheduler beyond those in the pair of hotfixes for W7.
Performance goes as
W8 > W7 + automatic patches > W7 + manual patches > W7
Agreed with the iGPU thing. Unplayable. But they wanted to make sure to have a GPU bottleneck with the iGPU and a CPU bottleneck when testing the CPU part. So it makes sense, especially if you just want to find out the performance improvement over the predecessor.
I get 18.6 fps in the x264 benchmark with a 3930K@4.2 GHz, hyperthreading off.
Fits perfectly. If Haswell overclocks better than my Sandy-E, I will replace it.
You still don't get it. THERE ARE NO WINDOWS 7 MACHINES WITHOUT THE UPDATES
the rest of stuff included in the updates was assumed in "W7" and "W8".W8 > W7 + automatic patches > W7 + manual patches > W7
I wrote "patches"
Anandtech has a list of gains offered by the manual FX hotfixes, several games showed 5% gain. The maximum obtained by improving the scheduler in W8 was 10%.
IDC is right, it is starting to catch on 😛galego, have you personally used either a Bulldozer 8150 or a PilerDriver 8350 machine? A simple yes or no will do.
Guskline, the dogged, determined man that he is, has been pursuing this question across something like 5 threads and 2 months now. :thumbsup: He deserves a medal for persistence in the face of being completely ignored nearly every time (I think he got a tangential sarcastic response back once).IDC is right, it is starting to catch on 😛 [snip image]
