This information would have been nice to know well ahead of time, but I can't find anything on the internet to back up what you're saying except for one or two people at the now-abandoned FrozenCPU site.DO NOT GET SILVER FROM ANY WATERCOOLING STORE.
AGAIN... DO NOT GET SILVER FROM ANY WATERCOOLING STORE.
Do not trust the purity of it, because there has been a LOT of bad batches of impure silver flooded on the market.
unless the store actually buys the pure silver sheets, and cuts them themselves do not trust silver from any store.
if you would like to use silver, get a 99.9999999% pure silver sheet and cut it into a coil.
most of the vendors who have voided warrenty because of silver have done so because of the bad batches which were flooded.
Sterling Silver is NOT PURE silver.
instead use a antimicrob additive, if you do not wish to go the route of purchasing the silver sheet yourself, or look for an original "iandh Silver coil"
That is the ONLY brand i will trust.
I have a kill coil, so I guess I'll use that instead, but from what I've read the kill coil can end up vibrating in the pump/res unit which would be extremely annoying. =\
I doubt you'll be disappointed then.
Guess it depends on what you consider low voltage in the end.
Did you see this review from Tom's Retail boxed with 5 cpu's tested?
http://www.tomshardware.com/reviews/overclocking-retail-intel-core-i7-5960x-cpu,4237.html
Good luck on the adventure!
Good stuff. I'd be perfectly happy if I could reach 4.2GHz on the 8-core with < 1.3v, but if I can reach 4.5GHz at 1.3v then I'd also be comfortable with that seeing as the water should be able to keep the temps under control.Between 4.1 and 4.2 will be faster per core than your 4930K@4.4Ghz. I doubt you'll have too much trouble pulling off 4.2GHz. My daily 4.5 overclock is roughly on par per core with my 3930K at it's balls to the wall 5.1GHz bench setting. Depending upon the particular test of course.
Unless you are doing rigid tubing throughout, I wouldn't worry with it for just the GPUs. I went with these. They worked out very nice. Bitspower also makes them, but I couldn't find a single place that had them in the length I needed in white, so the Swiftechs got the nod (much less expensive).
http://www.swiftech.com/connectors.aspx
I would have probably started with rigid tubing had I realized that you don't actually need to make those pretty bends with a heat gun (something I wasn't all that confident in doing as a beginner). I know that the pretty bends look... well, prettier, but I was thinking that I could just learn how to cut it and work with it, while using a lot of 90 degree connectors and what not. I also understand that that all those connectors will probably end up restricting some of the flow, but in my opinion it's all about learning what does and doesn't work for you. Not only that, but if the temps are still under control, even with a bit of restriction, then I'm okay with that.I agree with YBS1 in the connector. I use the same type between my 2 R9 290s with EK blocks and it works great. Much easier than trying to cut EXACT sizes and hoping they fit.
I was thinking either EK or XSPC waterblocks for the GPUs, and both of those come with their own special "spacer" for between each block, so I should be good.
My only fear with cooling the GPUs is if I have to RMA one of them for whatever reason, because then the entire system is pretty much down and the loop will need to be deconstructed until a replacement comes in, or modified while that one GPU is absent. I guess I just have to cross my fingers and hope that I can continue my streak of never having to RMA a GPU.
