- Feb 18, 2008
- 161
- 0
- 71
Ok im doing my first overclock i have been doing alot of reading on forums as well as tech blogs.. it sounds like this is gonna be fairly easy. just adjust the fsb to about 445 with the multiplier at 9, maybe bump the v core up a bit... however i know you guys have all kinds of knowledge that i can never get from reading forums... basically i was wondering if you could just give me some tips on simple things i may have missed like other bios settings that need tweaked you know just stuff that you have came across in your OC'ing.. cuz i really need all the help i can get i dont wanna mess my new rig up
and i have a couple specific questions
1. how do you know when to bump vcore up and what is the "healthy range", specificly what should i not go over
2.using software to messure my temps what i try to keep my temps under, cpu, chipset
3.what ram timing do you suggest and since im using 1066 ram will i even need to touch anything with my ram since it should be able to just handel the speeds for the overclock stock right?
the setup
CPU:E8400 batch q747a
Cooler: Zerotherm Nirvana 120mm
MOBO: EVGA 780i ( EVGA 132-CK-NF78-A1)
RAM: Crucial Ballistix 2GB (2x1gb) ddr2 1066 (pc2 8500)
GPU: msi 8800gt 512 w/ msi after market cooler
PSU: Antec Earthwatts EA500 500watt
Sound: x-fi gamer
HD: Seagate 200gb 7200rpm
random dvd burner
Case: random with rear 120mm fan and side panel 80mm vents in front for airflow
thank you guys soooooooooo much for the help
the setup
Sound: x-fi gamer
random dvd burner
