Hello, this is my first time building an HTPC and I wanted your opinions on the parts I've chosen. I'm not totally sure if I'm going in the right direction for what I want.
I would be using this for media playback(Blueray and DVD) and storage, probably playing some light gaming, and then the usual Netflix, Hulu, Pandora. In the end I want this to replace my cable tv. I will also want to hook up a surround sound system or sound bar to get more of that movie experience. Any suggestions/changes are welcomed. My budget is about $500-600 if that helps.
CPU: Intel Core i3-3220 3.3GHz Dual-Core Processor
Motherboard: ASRock H77 Pro4-M Micro ATX LGA1155 Motherboard
Memory: G.Skill 4GB (2 x 2GB) DDR3-1600 Memory
Storage: Seagate Barracuda Green 2TB 3.5" 5900RPM Internal Hard Drive
Storage: Intel 330 Series 60GB 2.5" Solid State Disk
Case: Silverstone SST-GD05B-USB3.0 (Black) HTPC Case
Power Supply: SeaSonic S12II 380W 80 PLUS Bronze Certified ATX12V
Optical Drive: Lite-On IHBS112-04 Blu-Ray/DVD/CD Writer
