CPU - overkill on your budget (you don't need a K model)
Motherboard - overkill on your budget (you need only an entry level board for a locked i5)
Memory - can get the same specs for cheaper, e.g. ken's build
Storage - hard disk is good... but no SSD
GPU - the R9 280 I linked is a better deal, but as far as GTX 960's go, MSI Gaming is excellent
Case - overkill, you're on a tight budget so pick a case that's the bare minimum without being bad, e.g. Bitfenix Neos or Core 2300 at most
PSU - mediocre quality, go with the EVGA 750W because it's such a good deal for $80, and much better quality (with longer warranty to boot)
Optical - OK
Case fans - unnecessary extras
Peripherals and OS are missing, if you added $300 for these you'd be $190 over your $1150 target with this build.
Everything as above, except
CPU cooler - OK, but not necessary. If you just intend to keep the CPU properly quiet, get a
Pure Rock
Video card - HIS R9 280 3GB is still better value, and MSI Gaming would be a better GTX 960 model
Also, i looked at Ken's build but, I'm not fully sure that I want to adopt it, I want maybe something slightly better (i5-4690 instead of the i5-4460, stuff like that)
i5-4590 ($250) and i5-4690 ($260) are both fine, as long as paying that extra $20-30 over i5-4460 doesn't hurt other parts choices.
Finally I have also looked to improve my primary build, tell me if this would work
I keep the same parts but i change the storage and power supply:
Power supply :
http://www.amazon.ca/Bronze-Certifi...=1437570472&sr=8-4&keywords=EVGA+power+supply
The EVGA 750W B2 is still a better deal since you can get it for $80 after rebate. That 600W unit built by HEC and covered by 3 year warranty, while the 750W unit is a better Super Flower build with 5 year warranty.
For $80 without rebate, I'd go with
XFX 550W.
Yep, that's fine.
The problem is that when I convert this in canadian dollar i think it will cost something like 1100$-1200$, I have to check if i can afford this.
That doesn't include Windows nor peripherals, correct? Those will cost you another $300 or so.
