frozentundra123456
- Aug 11, 2008
- 10,451
- 642
- 126
Go Pack Go!
Go Vikings Go!!!
I can always dream, I'm from minnesota.
Go Pack Go!
This RAM is slightly cheaper than yours, I think:
http://www.newegg.com/Product/Produc...D=3938566&SID=
The SSD doesn't seem too necessary. A 1TB mechanical hard drive is cheaper and you get more storage.
I am not too versed with video cards, but according the nomenclature of Radeon cards, a 7770 is significant step down from the 7870. I'll let those who know more than me to highlight what you're giving up.
I do not like the FX 6100 choice because it's a Bulldozer. The Piledrivers are better and the i3s are better than it performance-wise. Since you have access to the Micro Center, consider if you can make room for the i5-3470 that is going for 150. The FX 6300 or i3 3220 would also be something to look at there.
if you can try to get a Vishera chip instead of bulldozer or intel i5
For gaming? You can't be serious.
http://www.anandtech.com/bench/Product/697?vs=701
For encoding, maybe. There's a nuanced argument as to when vishera is a better choice than Ivy Bridge. Yours is not one of them, but then again, you list no GPU in that vishera system of yours, so you are evidently not a gamer.
