first build horrors
kparms82
37
You can buy a splitter that turns one fan socket into 2 for really cheap.
The best thing to do when putting a comp together is to take your time, and have fun.
I always mount the proc/heatsink first outside of the case, cause that is just way easier. thats the hardest part, everything else just falls into place after that
450R
319
Kept losing screws underneath the motherboard. Didn't even know I was supposed to install stand-offs. Couldn't figure out which way the IDE cables went. Listened to a Duron bend when I put the HSF on. Finally got the HSF on the Duron only to realize the motherboard tray wouldn't go back in with the HSF installed. Bled a lot. Tried to put molex connectors in upside-down. Forgot to connect the CPU fan. It worked fine in the end ... for 6 months, then it burned straight through the OEM thermal pad and died.
It was the second build that I tried AS3 ... I have very shaky hands. That sucked.
iamtrout
3,001
Lifted my motherboard up by the HSF. Cracked the core of my Duron underneath the HSF with the uneven pressure.
Jeff7
41,596
20
Floppy power connector != CD audio cable.
Killed a cheap soundcard that way; it gave its life to save the motherboard though, which was some old socket 7 thing.
Vee
689
Originally posted by: MisterChief
Anybody ever "static" their system to DEATH? I've never heard of a comp that got zapped and broke down.
That attempt would be difficult enough to profit by some intent and some knowledge of how to exactly apply the zap. ;)
And yes, I've done it. Twice even. :eek: But it was a long time ago, and I don't think I quite deserve that all the embarrasing details are posted.
The question itself does somewhat, to me, suggest a misunderstanding about the threat of static electricity to computer hardware?
Computer components are generally not damaged by "zapping", but by ordinary, always present, static differentials. These are much too weak to be ever felt or noticed as static charge. They are however quite enough to damage microscopic transistors and capacitors, intended to cope only with ~1½V and a few electrons.
You easily avoid this by never touching pins, leads, solders or connectors. At least not until you've been in contact with the component for a while. Similarily, you do NOT immediately connect two components, so that they make their first contact with their connectors or other conductive parts. Instead, equalize potential first, by touching both parts with the same hand simultaneously. Then bring the connectors together.
The whole idea is simple. The electric potential between two objects should be equalized, but never through any of the the circuitry. As long as this does not entirely depend upon chance and good luck alone, static really isn't much of a problem.
Persons receiving a lot of "bad" components, should perhaps review their habits.
powerMarkymark
2,164
The screwdriver slipped while installing the heatsink and I damaged the motherboard, costed me a (2nd) new motherboard.
Monkey muppet
1,241
When I first started gaining an interest in system building a purchased a new graphics card (ATI all-in-wonder 32mb or a Vodoo 2, can't quite remember). I was there for quite a while to trying to figure out why I couldn't fit it. Only to notice that it required an AGP slot.
This was back in the day when 64mb RAM cost around $200
psebas
Banned
Oct 6, 2004
88
Never , EVER !!! , spil a can of coke in a crt monitor, it goes to hell with a BANG!!!!!!.
MrBond
9,911
Dad and I building a computer together, I think it was a Cyrix 166 or something, definatly not an intel chip since they were so expensive back then. Anyway, we get it together, boot it up, but the floppy drive is always on. Easy enough, Dad reaches in (while the PC is on), unplugs the floppy power, flips it over, and plugs it in again.
Yeah, let the factory smoke out of that power supply :D. We spent more bonding time driving out to the store to get another case/ps :D
He even knew it was a bad idea, just wanted to try and save some time.
bait
33
didn't know about using the screwdriver for installing the hsf...so i hooked that side first, and pushed down on the other side with my bare hands thinking how weak i was compared to everyone else. finally clicked but...if it bent the cpu, i don't know about it. kinda scared now, but everything's working fine for months so....
imported_NoGodForMe
452
A long time ago, in another life, I replaced a MB into an existing case. Think it was a 386. Extra standoff was under the MB and shorted when I turned on the power. It popped, I smelled the smoke, and that was it. Lucky for me, I bought the parts from this reseller I knew locally, and he returned all parts and gave me my money back.
MrControversial
848
Spending $1500 and finding out that my system is still horribly outdated because I failed to read reviews, messageboards, etc.
strend
47
I had a heatsink fall-corner first-directly onto the core of my shiny new 2000+ as I was changing grease.
Jan 16, 2005
62
I was installing a 6800, and there were 4 BIOS updates available on the web site. So, I grabbed the new one, flashed it, and lost all video signal. Put 5200 back in, got next newest, put 6800 in, blind-flashed it, no worky. put 5200 back in, got next newest BIOS, put 6800 in, blind-flashed it....and it worked. Thank god, I was ready to give it to the cat.
Coalfax
400
82
101
Always use standoffs when installing a new Motherboard into a metal case...
Images of a friend who screwed the darn thing directly to the side panel of his mid tower and then proceeded to turn it on. FOOM!
Was interesting, for about 2 milliseconds :)
slash196
1,549
I was installing a video card on a system with integrated graphics. It took me TWO HOURS to figure out that the reason nothing was showing up on the screen was that I needed to plug the monitor into the new graphics card, rathing than the IG port. I didn't even feel stupid, just relieved.
hagg3rty
347
Having an awsome Athlon 64 3000+ like 6 months ago with a Geforce 2 because of bad budget panning!
leedog2007
396
my brother was putting his mobo/cpu back in his case (new) and he was holding it by the HSF and the mobo hit the side of the case and a piece of the pcb cracked off. the mobo was ruined.
Arcanedeath
2,822
When installing my SLK900A heatsink the screwdriver sliped and put a very big scrach in my Asus A7N8X Deluxe Rev 2.0, but I got the heatsink on and my 2500+ has been rock solid @ 3200+ speeds for a long time now, so seems I didn't realy do anything but cosmetic damage. Man was I relived.
VirtualLarry
56,587
10,227
Dude! You should have bought a Dell! No, wait... you would be in the same position. :p
Wadded Beef
Banned
Dec 15, 2004
1,482
well looky here...theres an extra power thingy coming from the power supply, (5v floppy connector) i'll bet it goes in here! (fan connector on the motherboard) needless to say it killed the mobo, but I bought the motherboard locally and got a free exchange, god i was such a noob =p
