Looking up that H57 board on newegg shows it to be a LGA1156 board (for the first gen Core-i processors). For SandyBridge processors (second gen Core-i2) you need LGA1155.
I mentioned four different chipsets for LGA1155 boards. In simplistic terms, the new Z68 chipset gives you access to most features, like QuickSync, integrated graphics & K-model overclocking, but is likely to be more expensive. P67 allows K-model overclocking, and is recommended if you rely on an add-in graphics card (like your 4850). H67 has the QuickSync & integrated graphics features already mentioned, but no overclocking; AFAIK H61 is a budget cut-down version of H67 (typically on smaller form-factors).
Lulu's suggestion of "Intel Core i5-2500K + GIGABYTE GA-Z68A-D3H-B3" is a good place to start because it covers most bases. If you need something cheaper, then there are plenty of options at lower price points (e.g. motherboards with fewer features).
the price of the board Lulu's suggested is fine i was just asking to see if i can understand the reasoning for choosing a particular board over another....
