There are a number of USB2+FireWire combo cards available. There are also plenty of front panel units that can handle each format. The only unique feature of this kit is that it may use a regular IDE cable between the two. You can achieve the same results by mixing and matching components.
Be careful with the FrontX unit, it's not a hub but an extender. I made that mistake with a similar unit and promptly returned it. I bought a USB 2.0/Firewire Combo Internal Hub from Bytecc through Ebay a couple of weeks back - works great.
