ThatsABigOne
Great eye catching bike! Congrats. 🙂
You will need the fueler, the air cleaner is a tossup. A PC-III or V would be the least expensive option, there almost has to be a map around for the combo you'll be using.
The apes would be alright as long as you don't go to high, there is no way in hell I'd put whitewalls on that bike though.
Power commander installation
http://www.powercommander.com/downloads/817/install/511/eng817-511.pdf
Simple as taking off the seat and unplugging a few things and plugging in the power commander connections. After install you will need to load a map into your power commander for your specific pipe which the manufacturer Dynojet provides. The maps Dynojet provides are going to get you close as far as running pretty well and not damaging your engine but a custom dynotune would be best as all bikes are a little different and the weather is different where you are as opposed to Las Vegas where Dynojet's facility is.
As far as the pipe install its a few flange bolts at the headers and probably a few other clamps. Look on YouTube for sportster or Harley pipe installs. Simple as pie.
I have the power commander III
Check out hdforums.com, they have a classifieds section and a ton of useful info on the boards
Mustang makes a really nice saddle as well, I've had mine for seven years and it's still really comfortable.
It looks like your '07 sportster only works with the power commander 3 not pc5. I'd look into it and make sure you get the right one. Also make sure you don't get the EX version which is the California emissions version which basically neuters your bike to comply with Cali's strict emissions standards. You might need some more exhaust gaskets to seal the headers. You can sometimes reuse them but it's nice to have a set in case the headers have an exhaust leak. They should be no more than $20 for the exhaust gaskets.
It should work with the 5 as well. The reason they say 08 and up is because the older bikes don't have o2 sensor bungs. That's the way it is with V-Rods, and I assume the delphi ECM in the air cooled bikes is the same unit.
Get the V&H quiet baffles. They lower the db by about 8.
You don't need to buy a FuelPak/Power Commander or anything if you just replace the exhaust. If you replace the air cleaner as well, then you'll want a tuner. Dyno tune is the best but it's expensive to have done. Just go with the X14ied system; easy as pie to install. The Fuelpak is an absolute whore to install (thing barely fits anywhere). I have one and I have it routed all over the place.
As for seats, Mustang pretty much makes the best seats according to most of the people I know. I've been riding stock for over a year and it's not that bad. A spring seat would be nice, too, which is what I'll be doing. If you want 2up you'll have to look at a seat with a nice pad for the passenger (as well as passenger pegs).
Some of the easier mods to do with a new bike are grips and bars. Grips can be a bit of a pain in the ass but it shouldn't take any more than an hour the first time. Any time after that will be 15-20 minutes.
Bars are relatively simple to install. Just make sure you don't get anything too long. As far as I know, with stock cables, you can run the 8" Road 6 Custom ape hangers (wasn't paying attention to the video, but I think those are the same bars, probably different height). To replace them just unscrew all the controls (just torx screws everywhere), slide it all off the bars, unbolt the riser clamp, take the old bars off, put the new ones on, then put the controls back on. Really hard to screw up.
Other good mods include removing the fork and fender reflectors (check the laws in your state before doing this). Just pry 'em off and use brake cleaner/wd40 to remove the goop; won't affect your paint.
Relocating the front turn signals to the forks is a decent mod. Relocating the speedo to the side of the bike cleans up the front, especially with apes. Can cost a bit though.
EDIT: Important addition. If you ever screw something on, make sure to put thread locker on it. Blue loctite works for this. Don't want mirrors and turn signals flying off.
Wow, thank you man.
So you are saying I can put on the V&H Short Shot exhaust pipes with quiet baffles without the need to install anything further?
And, are these the bars you are talking about: http://www.seegercycle.com/road-6-custom-bars.aspx
He's saying you can change the pipes if you install Xied's. They're voltage dividers that install between the O2 sensor and the ECM. They drop the sensor voltage so the bike runs at a lower AFR when it's in closed loop.
Those are the ones. Check here for the full selection.
Roland Sands makes them as well, fair bit nicer but much more expensive.
The R6C bars will work just as well. The welds are good.
Those are absolutely hideous. I don't understand why anyone would want something so angular on a bike with so many round shapes.
