Final Build Review & Comments
G.M.Cottonwood
21
Hey guys I'll be using this rig for mainly video editing. This is the final configuration, tell me if I should make any changes, if there are any inconsistensies, anything else I need, or any other relevant comments. This is my first build also so any suggestions are welcome.
CPU: Intel Core i7 3930k Sandy Bridge
http://www.newegg.com/Product/Produc...82E16819116492
Motherboard: ASUS P9X79 PRO
http://www.newegg.com/Product/Produc...82E16813131800
Graphics Card: nVidia Evga Geforce GTX 670
http://www.newegg.com/Product/Produc...82E16814130782
Boot Drive: Samsung 840 Pro Series 512GB SSD
http://www.newegg.com/Product/Produc...82E16820147194
Hard Drives: 4x Seagate Barracuda 3TB
http://www.newegg.com/Product/Produc...82E16822148907
Case: Corsair Obsidian 800D
http://www.newegg.com/Product/Produc...82E16811139001
Optical Drive: LG Black
http://www.newegg.com/Product/Produc...82E16827136250
Power Supply: Corsair TX650w
http://www.newegg.com/Product/Produc...82E16817139020
CPU Cooler: Noctua NH-D14
http://www.newegg.com/Product/Produc...82E16835608018
Ken g6
Moderator
Dec 11, 1999
16,648
4,589
75
Where's the answers? :p ([thread=80121]Here's the questions.[/thread])
I don't see anything wrong other than you're paying a lot of money.
Hubb1e
396
Don't forget windows professional or you won't be able to use that 32GB of RAM. Also, if this is video editing you may want to go easy on that video card unless you're using CUDA of course.
Sleepingforest
2,375
You can actually use the normal version of Win8, if you're willing to use Metro.
Nov 26, 2005
15,189
401
How much performance does socket 2011 offer e.g. 3930K over an 1155 e.g. 3770k? I haven't checked in a while but I would guess not much vs the price difference, unless you are in Holly wood doing this as a profession and see the money easily justified...
G.M.Cottonwood
21
Well, for gaming 3700k would be fine (There would be no difference) but for video editing the extra cores, X79 chipset features, and the extra performance really do give a boost for video editing.
G.M.Cottonwood
21
Another person on another forum just pointed out to me that a Noctua NH-DH14 may be to big for this, apparently it will cover some of the ram slots etc... Is this true?
G.M.Cottonwood
21
In what app, and are you using video card acceleration?
Could you please clarify what you mean by video card acceleration? and I use Adobe Priemere, Adobe After Effects, Red Giant, and many other video editing appllications I dont use benefit from a 3930k. Its generally good for any editing operations.
mfenn
22,400
www.mfenn.com
What was wrong with your other thread? Posting a new thread on the same topic means that everybody loses the context and we have to ask and answer the same question over again. For example:
I have a question for you OP, what is your monitor setup? If you don't already have a 30" monitor, then you'd be better off from a productivity standpoint by buying one of those and then getting a $1500 PC.
G.M.Cottonwood
21
This is updated though, its not the exact same. This is after I took everything into consideration from all the websites.
Sleepingforest
2,375
Right, but it would be contextually identical, so it makes more sense just to update your old thread. You can tell from some of the initial responses that it wasn't immediately obvious that we've been working on a build.
