Few General Cpu Questions
Pixle
435
What should the temperature limit for the AMD 64 3400 socket 754 be at. 60(c)?
How much arctic silver should be applied to it, (should only a grain of arctic silver in the middle of the cpu be applied? Or all over evenly)?
Is their definte damage to the cpu or socket if the cpu was pulled out with the lever down?
Thanks,
Pixle...
SirOblivious
72
Can't say Im an expert at all, but from what I hear you place a small amount in the center and spread it over the cpu mainly concentrating on the core with an old credit card or something similar.
If their are pins bent/missing, then yea theres definite damage. If you jerked a pin out, kiss it good bye. Bent pins I think can be repaired VERY CAREFULLY, but ask someone else with experience dealing with this before you try to repair it yourself.
Pixle
435
Thanks...i'd really like more info on installing the arctic silver 5. ....
I hope the cpu works.
Pixle
435
if the CPU pins are ok...but their is a small crack in the sides of the silicon...should it still work?
Rike
2,614
There's one way to find out: Put it in and see if it posts.
