just a note: I _think_ even if you download through p2p or get if from a friend, it's still legit. I mean, under the GPL it would have to be. The support is what they are selling, not the ISOs. Redhat just decided to be a jick and make it difficult to obtain the ISOs. I was just saying, there could be something flakey if you got it from p2p without verifying an md5 sum. But you didn't, so not an issue, I just felt like pointing out the legitimacy was not my point earlier.Originally posted by: n0cmonkey
Downloaded ISOs from redhat. It's 100% on the up and up (work, not personal). 🙂
But like I said, I've never used official RHES, so I don't know of any differences in the install. Maybe you could try out CentOS and then I KNOW you will have an option for a "minimal install."
So do you have an option to customize packages? If you just unchecked the x server, then maybe it got added back in due to dependencies of another package that was left checked. Try scrolling all the way to the bottom of where you customize packages and see if there is an option that says "minimal install"
