fear of getting STDs
Radford University @ Radford, VA = highest STD rate in the nation. You should see the sluts over there. Jeezus, you're lucky to find one without STD.
Originally posted by: OS
i read a study somewhere that suggested at the current rate of increase, by 2050, half of all women in early adulthood would have genital herpes.
Casual sex is kind of overrated anyways. You don't have to buy into it. A lot of those people you mentioned probably already have STDs and don't know it, or keep it to themselves. They sure as hell aren't gonna tell you if they got treated for genital warts or anything.
BTW, condoms won't really protect you from genital warts and HPV.
Something like 3/4 sexually active adults have HPV. It doesn't usually manifest itself. So I wouldn't worry too much about it, it's basically unavoidable. Genital warts is just the outward manifestation of HPV, as far as I know.
Condoms also doesn't stop herpes. I just try to check out the inside of their mouth and their package before I get too close. This one's pretty much unavoidable too, like you said in your post.
25% have it now (genital herpes) so it is not unbelievable. I lucked out in my early years I guess but I suggest the OP proceed with caution.
Originally posted by: BannedTroll
Originally posted by: z0mb13
easy girls = std factory
Trust me it isn't just the easy girls.
Yup, after the guy fvcks 20 easy girls, he decides he'll put in the effort to get the 'good girl.' Hell, maybe she's even a virgin. But when he finally finishes his mission, she has an STD.
JMU is almost the same IIRC. STDs are airborne at Radford. 🙂
You're at VT, right?
Originally posted by: Fingers
Church isn't always the best way to go. Had a ministers daughter once and she was the kinkiest slutiest girl I've ever been with. Man I miss her.
*ahem* :camera:!!!
Provided this wasn't ATOT 20-25% of the people who posted in this thread would have herpes.
and 70-80% would have been exposed to HPV.
Fortuntely, it's ATOT, so you could sleep with anyone here quite safely 😉
One night stands last till morning but syphilis lasts a lifetime
so better safe than sorry. if you dont miss it then it is no big deal.
as other members had mentioned, condoms do not protect you fully from diseases. this is because your testes (your sacs, your balls), aren't covered and will be moisted during action. moisture means your pores are open and you can become infected through your testes. so if you really are goign to use a condom and want the maximum protection, use a condom that covers your testes also. do not have the female use any foam, gel, etc... if you are using a condom, because it could cause the condom to tear (just blow up a condom into a balloon and rub vaseline on it and it will pop).
Originally posted by: Nebor
You're being paranoid. Use a condom and live your life.
One thing is if you don't ant to be with the "easy girls" but if it's just because of STD just use condoms.
Originally posted by: kranky
CONDOMS DO NOT PROTECT AGAINST ALL STD'S !
Geez, where do you people get your information?
which doesn't it protect against? (except for those living in saliva, which also can be transfected using same glass drinking from same bottle etc.)
Condoms aren't effective in preventing the spread of HPV, one of the most common STDs.
The failure rate of condoms is quite high for pregnancy & STD transmission, ideally, it's only 2-3%, but in real life it's as high as 25%, depending on how you group the users/failures.
