Faulty PSU?
Discussion in 'Power Supplies' started by eggcase, Dec 9, 2012.
  1. eggcase
    eggcase Junior Member
    Dec 9, 2012
    4
    Hello all! I was hoping that someone here can help me. A friend of mine has been having some trouble with his video card and I'm not sure if its because of a faulty PSU or simply a video card problem.
    He says whenever he plays any game his display becomes corrupted with thick or slim static lines going across the screen. His monitor then turns black or blue then his PC freezes.
    When he restarts, the PC is able to successfully reboot, however the lines do not go away. Its only AFTER he does a system restore to a point when he didn't have any video card drivers installed is when his system works fine with no corruption on his monitor.
    However since he doesn't have any video card drivers he can't play any games.
    He did uninstall his drivers (together with driver fusion in safe mode) reinstalled a fresh copy of the drivers but unfortunately the lines come back on his screen.
    I then asked him to take a screenshot of a utility called SIW so I can take a good look at his GPU temps (s17.postimage.org/7u1xq4oxr/temp.jpg). When he did that, I noticed his voltages on his rails being a bit high.
    Since I'm not an expert in this area I told him that I would post on here to find out more about his rails, so I was hoping someone here can take a look at the rails and please confirm if his rails are within tolerance range.
    His system specs are also here:
    Antec 902
    Gigabyte GA-P67A-UD3-B3
    i7-2600K Processor 3.4GHZ
    16GB system ram
    Radeon HD 6870
    Corsair CMPSU-750AX
    1 TB HARD DRIVE
    1 Flash Media Reader
    Onboard Sound
    Sceptre X226W
    (friend typing, i just received this summary from my buddy, and was too lazy to rephrase)
  2. Loading...
    Similar Threads - Faulty Forum Date
    No resume from S3 (suspend to ram) - Faulty PSU? Power Supplies Dec 31, 2013
    Worried that my new build has a faulty PSU Power Supplies Jan 5, 2013
    Suspected faulty psu Power Supplies Mar 25, 2011
    faulty psu? random reboots after upgrading to x2 4200+ Power Supplies Sep 23, 2007
  3. TemjinGold
    TemjinGold Diamond Member
    Dec 16, 2006
    3,046
    65
    I seriously doubt it's the PSU. Has he cleaned out his video card recently? Sounds like it's either overheating or failing.
  4. eggcase
    Dec 9, 2012
    4
    cleaned it thoroughly and the lines are still there, does that mean the voltages are fine?
  5. eggcase
    Dec 9, 2012
    4
    update:just tested the readings on hmonitor
    http://img138.imageshack.us/img138/997/temp2wm.jpg
    ... and the voltages look fine, meanwhile siw still shows the same readings.
    so which program should i go by? SIW or hmonitor?
    i also noticed that the 'graphics adapters' show nothing. do hd 6870s usually have sensors? or is the card really dead?
  6. Piotrsama
    Piotrsama Senior member
    Feb 7, 2010
    357
