You will still have any drawbacks of SLI if there are any.
It's all about perception. Added value, user experience.
I think its pretty cool. It will be $500. I could see it being okay for someone wanting a unique card or quad-SLI in mATX, but other than that it seems rather pointless.
760's are slower than 7950's, especially if the 7950's are OC'ed. You are going to need faster cards to get higher FPS.
WOT does not support CF but does support SLI. I was getting 120 fps maxed at 1080 on a single 7950 but once I went to 1440 all I see is 65-maybe 90. Adding a second 7950 did not help at all. SO Im looking for a single card solution but you may be right, it maybe bottle necked to my cpu. Without going underwater or buying a different chip I cant really fix that.
Playing BF3 I see crazy high FPS on my setup
according to overclock3d, its msrp is $700 usd, which is almost the price of two 290's, maybe those numbers are wrong, otherwise It's a waste of time to me
It's only equal to the 780ti at its best, and it uses more power.
Should be using full GK104 dies for a $700 price, perhaps even cheaper.
quad-SLI with 2GB GDDR5? For what, bitcoin mining?
If that is the case, then yeah it is indeed pointless because SLI 760s can be had for $520 bucks. A single card should not cost more for the same performance.
Well, the card is plenty fast. Now they just need to get the price right.
Review up at Guru3D
http://www.guru3d.com/articles_pages/asus_geforce_gtx_760_mars_review,1.html
Oddly enough, even though 2GB of memory sounds puny...it performs equally as well as the 290X at 4K with twice as much memory. Just goes to show that marketing the 290X for 4K is just marketing jibberish. By the time 4K becomes relevant all of today's cards will be obsolete.
I found this on reddit
http://rog.asus.com/276632013/graphics-cards-2/faster-than-titan-rog-launches-the-mars-760/
it's a dual gtx 760 card, I've been wondering for the longest time why manufacturers don't make dual mid range cards, and it's finally happening
will this make me change my mind on the 290? Can't wait to see
