Originally posted by: JBT
I don't see whats so wrong it has AA on and its only a 9800 Pro.
Could you please re-test using my settings?
Thanks...
using your settings
TimeDemo Play Started , (Total Frames: 3726, Recorded Time: 67.36s)
!TimeDemo Run 0 Finished.
Play Time: 60.57s, Average FPS: 61.52
Min FPS: 40.20 at frame 882, Max FPS: 114.55 at frame 1945
Average Tri/Sec: 11247426, Tri/Frame: 182830
Recorded/Played Tris ratio: 0.78
!TimeDemo Run 1 Finished.
Play Time: 60.84s, Average FPS: 61.25
Min FPS: 39.27 at frame 831, Max FPS: 119.24 at frame 1921
Average Tri/Sec: 11352663, Tri/Frame: 185364
Recorded/Played Tris ratio: 0.77
!TimeDemo Run 2 Finished.
Play Time: 59.83s, Average FPS: 62.27
Min FPS: 39.27 at frame 831, Max FPS: 121.10 at frame 1918
Average Tri/Sec: 11445691, Tri/Frame: 183801
!TimeDemo Run 3 Finished.
Play Time: 59.70s, Average FPS: 62.41
Average Tri/Sec: 11552430, Tri/Frame: 185096
!TimeDemo Run 4 Finished.
Play Time: 60.17s, Average FPS: 61.92
Average Tri/Sec: 11493592, Tri/Frame: 185621
!TimeDemo Run 5 Finished.
Play Time: 60.20s, Average FPS: 61.89
Average Tri/Sec: 11537348, Tri/Frame: 186405
Recorded/Played Tris ratio: 0.76
!TimeDemo Run 6 Finished.
Play Time: 59.57s, Average FPS: 62.55
Average Tri/Sec: 11449879, Tri/Frame: 183053
!TimeDemo Run 7 Finished.
Play Time: 60.33s, Average FPS: 61.76
Average Tri/Sec: 11420550, Tri/Frame: 184921
TimeDemo Play Ended, (8 Runs Performed)
I perfer the look of using 1600 x 1200 with no AA much more than low res and AA thats for sure.
