13Gigatons
- Apr 19, 2005
- 7,461
- 500
- 126
Originally posted by: RossMAN
Ghost 9.0 seems easy for n00bs like me.
Is Acronis True Image just as easy for n00bs?
Probably even easier
Ghost 9 ships with Ghost 2003 (Version 2), which corresponds to 7.5.Originally posted by: SUOrangeman
FYI, the version of Ghost 9 I've seen actually comes with Ghost 8. Can the new version be that good if the old version still ships with it?
Originally posted by: GAZZA
I have used the new 9.0 and am getting ready to go back to the old dos boot menu instead with ghost 8.0.
Sure it's nice to use in a windows enviroment but if you only have one partition on your hard drive with no other to image to, it will image fine to the existing hard drive but it Will Not be able to restore that image from the same place due to image being located on the drive that needs restoring back to, even though it was able to create the image on the same drive !
And my god is it freakin slow, took over 12 hours to restore a 12gig image file.
I once restored a nice AlienWare top of the range laptop with 2x60g 7200 drives in raid 0 with a dvd image and it took less than 6 minsand that was using ghost 8.0.
Originally posted by: tcsenter
Attention all Ghost fans! Heads up:
SYMANTEC GHOST SOLUTION SUITE VAR MEDIA PACK: Part No#: 701120 - $8.15 plus shipping (and tax where applicable)
I ordered this from Page Computers and they shipped it (I didn't purchase any licenses with it, as required by Symantec). This contains Ghost Corporate Version 8.2, NO ACTIVATION REQUIRED. The full suite also contains many features never before available in Ghost, aimed at system builders, VARs, OEMs, and network administrators.
To install only Ghost 8.2, from the Autorun menu, select "Install Symantec Ghost Corporate Edition", then select "Install Standard Tools" from the next menu. The full Ghost Suite will install only on corporate or enterprise platforms (e.g. XP Professional or Windows 2000, NOT XP Home). Installing only Ghost 8.2 as described will install on XP Home as well.
I'm curious as to the practicality of backing up a drive onto itself (particularly in your case, where you didn't even create a separate partition). Also curious as to why you think a drive that needs to read at one location, decompress, and copy to another location on the same drive would perform faster than a DVD being read at 16x (22,000KB/sec)
Umm...I did and Page shipped it. So yes, it appears I "can".Originally posted by: brucekatz
"I didn't purchase any licenses with it, as required by Symantec."
Can you do that?
