apoppin
Yep . . .Originally posted by: CP5670
I liked Far Cry a lot. The graphics were both top notch and so was the gameplay for the most part. I don't care for the default rendering style, but the cold one looks far better. With the HDR enabled and properly adjusted I think the game looks better than some newer ones like Doom 3 and HL2. I need to try out those 64-bit textures though.
This works especially well when you are on the Sinking Freighter . . . Get OFF it as quickly as possible, swim for shore and run to a Palm Tree . . . use above tactics . . . results: one easily defeated chopter.
Is that the part where you fight crow? What I did was to move two 4WDs down on that piece of shoreline before I went on the freighter, so I could just run to those and use the vehicle machine guns on him.
. . TWO - 4WDs :Q
i tried only one . . . that didn't work
. . . that's when i discovered the beauty of palm trees
The tree affords enough cover so you never take a single hit [as long as you keep the bulk of the trunk between you and the bullets] but can blast away when Crow pauses in firing or changes direction
