Globe/Acoustifan/Enermax are basically all the same, with the only difference being that Acoustifan uses a hard clear plastic.
The Nexus is very quiet but expensive and doesn't push much air even at 12V.
Sleeve-bearing fans are generally quieter than ball.
I got some 120mm Globes from Coolcases for $8 each (1 was DOA unfortunately), and they're all quiet and undervolt smoothly.
