T_Yamamoto
- Jul 6, 2011
- 15,007
- 795
- 126
This whole build is going to depend on either you prefer to put this together in an ITX case, ATX case, etcetc
Thanks - lots of good advice and inspiration!
I'm considering building two Ivy Bridge based systems. One desktop PC and one HTPC:
* HTPC:
-Low TDP IB CPU (e.g. Intel Core i3-3100, or perhaps even a mobile IB model, or the lowest rated IB Pentium model)
-4 GB RAM
-80 GB SSD (media is stored on server on Gigabit LAN)
-Mini-ITX motherboard
-No GFX card (use IGP, unless IB cannot do 23.976 Hz video properly)
-Optionally TV-card with CA module
-BD-R
-PicoPSU+PowerBrick, or optionally silent PSU
-Connectors Front: BD-R, USB
-Connectors Back: Standard motherboard connectors, TV-card cable jacks and CA module slot
I like the idea of building really small systems. So a case that looks like a MacMini or http://www.silentpcreview.com/HDPLEX_H3.SODD that ElFenix suggested would be nice. If such a small case does not have external heatsinks, do you still think it will be possible to build the systems fanless? Or will I have to get at least a PSU with a fan, or a low RPM 120 mm fan?
Also, do you think all of the above will fit in such a small case? My biggest worries are how to fit the multi card reader (requires 3.5" slot?) and BD-RW in the desktop PC, and the TV-card and BD-R in the HTPC.
Don't the capacitors and other components on the motherboard that regulate power to the CPU burn out faster this way? I read somewhere (probably in this forum) that the stock CPU heatsink/fan combo also cools these components.
