Fan Vibration
bbarnes
421
I recently took off the Heatsink Fan and the Northbridge Fan and painted them.
Now that I have them put back on, once I turned the computer on I noticed (heard first, then felt) that they are vibrating quite a bit...
I also painted an 80mm case fan, but it doesn't vibrate near as much.
What do you think it is, is it bad, and how do I fix it?
fatbaby
Banned
May 7, 2001
6,427
You may have gotten paint into the fans motor, now unless you are l33t and can ressamble fans at will, dissasemble it, sand off the paint...or buy a new fan
jiffylube1024
7,430
Make sure you attached it properly + tightly, just like how it came. Does that fan screw on? I don't think it does, but if so, then make sure the screws are nice and tight. Btw, why would you paint the CPU fan?
