mindless1
No, the clips mount on the bottom side of the fan frame not the top, so thickness is not an issue.
You do not need a 15mm fan. It just needs open ears on each corner of the fan frame so the clip can sit in the holes. In other words the average 120mm x 25mm thick fan should fit fine.
