Fan-free CPUs?
Daovonnaex
1,952
<< PPC chips generally run without fans. >>
expensive, proprietary, and by default come with a crap OS and a one-button mouse ;)
sun's come with 3-button mice - they must be 3x better :D
Crap OS? I suppose windows is the king of originality and stability, no? But I digress, a PPC setup would be good, but the newer ones have far more processing power than you need. I recommend the Transmeta Crusoe. By the way, does anyone know how many operations per clock cycle the Crusoe does?
By the way, while a Crusoe wouldn't work in this (Cyrix would though), the Shuttle SV24 sounds like something for you. Hot Hardware has a fine review of it (much, much better than Anandtech's "review" of it).
sparks
535
I slapped a fanless Alpha 8045 on a 1GHz TBird and I am running Seti@home 24/7. The PSU fan sits perfectly to the side of the cpu socket and it is adequate for my cooling purposes.
Daovonnaex
1,952
<< I slapped a fanless Alpha 8045 on a 1GHz TBird and I am running Seti@home 24/7. The PSU fan sits perfectly to the side of the cpu socket and it is adequate for my cooling purposes. >>
TBird without a fan? And it isn't burning?
Damascus
1,434
Get a used 486 or Pentium MMX and put it in a box with other quiet components.
You people recommending that Sofa go and get gouged by Intel by purchasing
a P3/P4 for routing duties are crazy and have _way_ too much money to throw
around. Hey! Throw some this way! :D
About PPC coming with a crap OS; you do with it what you would do with a
computer from any major builder, you replace the crap default OS with Linux. ;)
Barnaby W. Füi
12,343
<< Get a used 486 or Pentium MMX and put it in a box with other quiet components.
thats exactly what i was thinking. anyone recommending a p3/4/tualatin for a router/file server (running linux, no less) are absolutely insane.
get a pentium or a pentium 2 or a celeron. get a big heatsink and try to undervolt some, or get a silent 120mm fan for it.
that is more than you will ever need for this task.
btw, welcome to anandtech :)
thomsbrain
18,148
<< Get an old CuMine Celly 533 - it only puts out something like 15W and can be run just fine with a big honkin' heatsink on it. Sounds like you don't need too much power... >>
I have a 566@850 with a Globalwin FOP-32 that doesn't need a fan, even though it's overclocked. temps never go above 45C
OTR
50
for routing, an old fanless laptop could work. For file serving, you may need more disk space than an old laptop can provide.
