<< Which way is the fan on the CPU heatsink supposed to blow the air? Down towards the heatsink or away from it? >>
Some go either way. In tests, 99% of time you want it blowing air DOWN on the heatsink. Milage will vary.
Do I need a fan on the Northbridge heatsink (Iwill KK 266-R)?
Would I need one if I decide to overclock?
Thanks,
Dhanu... >>
If it doesnt come with one, doubtful. If you want high FSB overclock as opposed to raising the multiplier, then yes you want a souped up heatsink and fan on the northbridge.
