I?m trying to put the finishing touches on PC, silence wise. Right now I?m running all Panaflow L1As undervolted in my Lian Li 6070. I've heard decupling the fans from the case can help, Nickel020 posted some links (below) which look good. I was wonder though if I could just get some rubber washers and place them between the case and fan, and maybe do the same thing with the HD cage.
Thoughts, recommendations?
Originally posted by: Nickel020
I use something like this to decouple the case fans:
http://www.siliconacoustics.com/fanisolators1.html
this for the CPU fan (these rubber things are made by Verax):
http://www.silenthardware.de/f...ndex.php?showtopic=567
and this for the HD:
http://www.pc-cooling.de/catal...8&products_id=3924
