Maximilian
Originally posted by: PhatoseAlpha
Originally posted by: NoSoup4You
Not sure if anyone's answered this yet, but as to the original posters issues finding ammo, it sounds like he put only one point into Luck. Luck shoud be at 8 to start the game. Then you'll pick up the Luck bobblehead and the lucky 8-ball from Big Town to bump you up to 10 luck.
What luck does is increases your chances of critical hits, which helps conserve ammo! I also believe it increases the amount of ammo you find in crates, so you should be more than fine with ammo.
My first character only had 1 or 2 in luck and I had the same problem, no ammo... So I restarted and dumped 8 into Luck and I never had trouble finding ammo afterwards.
I didn't think luck was that useful, but even so, 8 luck is too high, since you forgot the +1 from the lucky shades.
At any rate, early on, if you don't know exactly what you're doing, the rock-it helps a lot. Effectively unlimited ammo since you can pick things back up.
Be sure to get a dart gun too. It kills nothing, but one shot insta-cripples both legs. Very handy on deathclaws or melee weapon opponents.
Yeah but really... you cant go through the game hurling burned out books or pre war money at people. Real men use guns! 😛
Early on i found the hunting rifle and 10mm pistol to be good, especially the hunting rifle. Although i had an extremely tough time on my first try because i had never heard of VATS which unfortunately made mirelurks near invincible vs me plus the hunting rifle is useless without VATS. A bat was my primary weapon for so long ugh...
