I reset my computer this morning and drove 35 miles to work today. All inputs except evaporative are completed and the light didn't come on yet. I think I should be fine without the evaporative indicator. That's usually checking the gas cap here in pa.
Edit: seems the readiness monitors reset if the ignition is turned off. After driving again they all become ready except the evaporative one.
Yea I know but I just had the sensor replaced the shop got it from Mitsubishi, and torque still shows pending fault code P0145.Evap requires a warm engine and a fuel tank that has less than 3/4 full but more than 1/4 filled as well.
I called in before bringing the car to get the sensor replaced telling them about the code I found. Of course they had to say the diagnostic is $90 and its more than just checking codes. They check codes for free but they said they have to test the afflicted part.IF the shop stated the sensor needed to be replaced and the problem did not go away; get the shop to reverse the charges
No my diagnosis doesn't matter. Anyone on google can look up codes that a scanner pulls. Any shop you go to here will do the diagnosis and charge you for it. I was charged $90 for a diagnosis and they took $21 off that charge looking at the details because I've been there for oil changes and had my inspection there. I was there for 2 hours, one of which they were looking at the car on the lift.I don't get it. You did the diagnosis and have them replace the part which you believe was faulty. They installed new OEM part per your instructions.
I hope you are right. But I think after they did the work they must have reset my ecu. So what I'm thinking is if the issue was fixed and computer reset why would it still show a pending code. I will know tomorrow for sure, I drive about 50 miles round trip to work.I imagine your code will be cleared. It is pending because it still needs to cycle. Give it a few days and a couple hundered KM's (miles, whatever)
I'm not sure which brand is standard. I think its denso but I'm not sure. Every shop I've called gave me the same price. I could have taken a chance and buy one on my own but the one guy who wanted to install it for me never got back to me.Op got ripped off buying "OEM" oxygen sensor... I mean $400 for a catalyst efficiency sensor.... wtf? The only time I've seen oxygen sensors cost that much is if they're really old wideband oxygen sensors but those are primary oxygen sensors that go BEFORE the catalytic converter, not after it. The simplest rule to getting a proper OEM replacement oxygen sensor w/o buying OEM is knowing what brand o2 sensors came with the car. The "OEM" oxygen sensor should say who made it like Bosch, Denso, NGK, etc. Typically if it's american or Japanese, it will be either Denso or NGK while if it's european, it's likely to be a Bosch.
Of course they gave you the same price, they were quoting OEM parts. A lot of shops aren't savvy so they'll default with OEM part. If you said you were supplying the part and told them that you didn't care if they guaranteed the work, just that it's installed properly, I think most shops would install it anyway. You don't need a parts warranty or diagnostic fee to install a fuckin o2 sensor lol and that's exactly what these yokels did.I'm not sure which brand is standard. I think its denso but I'm not sure. Every shop I've called gave me the same price. I could have taken a chance and buy one on my own but the one guy who wanted to install it for me never got back to me.
I've had shops install my own parts before. They were careless and some refused to do it in my area. If I had known exactly which part it was I needed to buy such as a denso model with oem fit, I would have bought it.Of course they gave you the same price, they were quoting OEM parts. A lot of shops aren't savvy so they'll default with OEM part. If you said you were supplying the part and told them that you didn't care if they guaranteed the work, just that it's installed properly, I think most shops would install it anyway. You don't need a parts warranty or diagnostic fee to install a fuckin o2 sensor lol and that's exactly what these yokels did.
Since they reversed the diagnostics fee, you might not have a whole lot of recourse since it's just cost of parts. But you did get screwed because you overpaid for the parts (dealer part ripoff, not shop ripoff).
The code is pending still and the shop assured me that if it comes on again they will figure it out and make it go away. If they want to charge me more for other parts to replace I'm going to refuse as they had the car for 4 hours and failed to diagnose it correctly if the light comes back on.No check engine light but I called back and told them about the pending code. They told me to go through the driving cycle and if the light comes back on to bring it back and they will make sure it doesn't come back on.
If they don't fix it I'll just call the credit company they have assigned to their card and tell them I'm not paying it until its fixed.
After that, I hope I can get an extension on the emissions past 30 days seeing how I paid a lot to trying to fix the issue. Follow their instructions and bring it back if it does not clear.
You paid to get it working using their diagnosis.
If they do not fix the problem within one more visit; then do not pay the bill; have them put the old part back in.
Then go somewhere else.
Make sure that you have a copy of their work for the emissions; they should allow an extension based on your good faith attempts.
For the record, I picked up a downstream O2 sensor for $12 (OEM), and it's within easy reach from above the engine. 30 seconds with a 7/8" wrench and I had the new one in place.
The downstream O2 sensor *should* just be there to check if the cat is working. AFAIK, they generally serve no other purpose than to fail you at emissions testing if your CAT is bad. Driving around with a bad downsteam O2 sensor will not generate any more pollution than if it's working right.
Some tests are continuous and some are non-continuous. Continuous tests run all the time and non-continuous run only when some of the enabling criteria are met.I notice that some emissions monitors reset to incomplete after engine shut off.
