Same machine ID is fine on a different box.What does it mean in HFM "client is working with the same user and machine id as another client" ? Am I loosing points ? these are on a different physical box. How do I fix it ? I just ran with "-configonly" to add the passkey.
FAHMon will be correct until you qualify for bonus, and then HFM will be correct.And it has my PPD way higher than fahmon, except my real ppd is the same as fahmon.
According to Stanford it is 10 per passkey with an 80% or better completion rate.So you have to do 10 units per client, not per passkey to get the bonus....
As long as they're on different boxes, it's fine. The notice may get annoying after a while, but that's the worst it'll get.What does it mean in HFM "client is working with the same user and machine id as another client" ? Am I loosing points ? these are on a different physical box. How do I fix it ? I just ran with "-configonly" to add the passkey.
Yes. HFM will be the more accurate one once you qualify for the bonus.And it has my PPD way higher than fahmon, except my real ppd is the same as fahmon.
No, it's 10 per passkey. It's just that the client shows the number of units completed on that machine, since it has no way of knowing how many work units other clients have completed, and even if it could, would not be desirable.Edit: I have one client with verbosity 9, and it has the below:
[20:08:26] Unit 4 finished with 80 percent of time to deadline remaining.
And those were all A3 WUs (p6011 - p6059)?Well, I say that, since I have done WAY over 10 for my passkey, 8 machines times 4 units ? thats 32, even if I am off by a few.
I would check the log to make sure that they are not identical WUs; if they are you need to reinstall one of the clients.And as for the message on HFM, it also shows the exact work unit on both boxes, even though its impossible, since one is local, and one is a network connection.
As in same project, as well as same run, clone, and generation?And as for the message on HFM, it also shows the exact work unit on both boxes, even though its impossible, since one is local, and one is a network connection.
This any good to ya? http://code.google.com/p/hfm-net/Quick question, since you all are talking about HFM.net, and I just started using it. Is there a FAQ or help file somewhere on this program? I have it working and my clients loaded but have a few questions.
Briefly summarizing our bonus formula, the bonus is applied for users who have a passkey, have successfully returned at least 10 bonus-eligible WU's, successfully return >=80% of assigned WU's, and return the WU before the preferred deadline. Bonus points do not apply to partial returns.
The performance fraction is basically a moving mean of the time it takes to finish a work unit. So if you have a performance fraction of 0.982710, then it means that you finish your work units with an average of 98.27% of the time to deadline to spare.What is the effect of the "updated performance fraction"?
Lol 😀Thanks Assimilator1. :thumbsup:
I was just there when I found and downloaded the program. Then promptly forgot...........😳
My memory is about as long as my ..................... Anyway it is getting shorter by the day. :biggrin:
