natethegreat
- Dec 5, 2004
- 899
- 0
- 0
Originally posted by: lmadern
Ok the P4 3.2 is taking 49 minutes per frame for project 1134 (my home Sempron 3100+ takes 31 minutes per frame for the same project) and it takes 31 minutes per frame on project 1310. So I guess if the P4 were doing only project 1134 it would take approximately 25 minutes per frame?
If that would be the case, my Sempron at home isn't doing too shabbily. Not a bad 200 dollar purchase.
Originally posted by: ProviaFan
And the SoB project (for one day), which is a fine project, but which was (is?) not compatible with dialup, which was all I had at the time.
Thanks... when I tried it probably at least a year ago, I don't think that existed. Now, I'm obviously fully committed to F@H, as that's my "home" project, and one of the few where our TeAm isn't next to the top (or at least in the top ten).Originally posted by: amdxborg
You can use SBQueue to queue wu for SB just like SetiQueue for SETI. SBQueue was created by our own Ken_g6 and can be found here!![]()
My newest Intel rig is a 500MHz Celeron, so I can't speak with great accuracy, but I think HT is an option that must be enabled in the BIOS (maybe it comes on by default). If HT is on, normally you will see two CPU usage graphs in the Task Manager, as if it were an SMP system (make sure on the Performance tab that View > CPU History > One Graph per CPU is enabled). If HT wasn't on when you installed Windows, you may need to either reinstall Windows after enabling HT in your BIOS, or go through a complex driver reinstallation thing to trick it into switching from a single CPU to dual CPU HAL (I think, but ask an expert on this first)...Originally posted by: lmadern
I know if you are running Win XP with most motherboards the P4's with HT are automatically recognized as such and it is enabled.
