F@H folks, I require assistance!
Originally posted by: GLeeM
Do a search on your hard drive for a file named: d3dx9_30.dll
The client needs this file. It missing has been a problem for others.
Originally posted by: CupCak3
FAH should not run with the d3dx9_30.dll buuuut just in case.....
ummm.. well, either way, it is on my computer.
run this:
http://www.microsoft.com/downloads/deta...-4c1b-bc6a-9b6652cd92a3&DisplayLang=en
Let us know if it solves anything 🙂
Afraid not.
Could you post some of your log file (probably named FAHlog.txt or something close to that). It could help us troubleshoot.
Here you go.. if you'd like to see more, I've got plenty...
# Windows Console GPU Edition #################################################
Folding@Home Client Version 5.91beta2
http://folding.stanford.edu
Launch directory: C:\Program Files\Folding GPU
Executable: C:\Program Files\Folding GPU\FAH5.91beta2-console.exe
[04:36:09] - Ask before connecting: No
[04:36:09] - User name: Cuhulainn (Team 198)
[04:36:09] - User ID: 63A99A9E098D2037
[04:36:09] - Machine ID: 2
[04:36:09]
[04:36:09] Loaded queue successfully.
[04:36:09]
[04:36:09] + Processing work unit
[04:36:09] Core required: FahCore_10.exe
[04:36:09] Core found.
[04:36:09] Working on Unit 00 [December 11 04:36:09]
[04:36:09] + Working ...
[04:36:09]
[04:36:09] *------------------------------*
[04:36:09] Folding@Home GPU Core - Beta
[04:36:09] Version 0.10 (Mon Oct 30 12:32:17 PST 2006)
[04:36:09]
[04:36:09] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 13.10.3077 for 80x86
[04:36:09] Build host: CYGWIN_NT-5.1 vishal-gpu 1.5.19(0.150/4/2) 2006-01-20 13:28 i686 Cygwin
[04:36:09] Preparing to commence simulation
[04:36:09] - Looking at optimizations...
[04:36:09] - Created dyn
[04:36:09] - Files status OK
[04:36:09]
[04:36:09] Folding@home Core Shutdown: MISSING_WORK_FILES
[04:36:14] CoreStatus = 74 (116)
[04:36:14] The core could not find the work files specified. Removing from queue
[04:36:14] Deleting current work unit & continuing...
[04:36:18] - Preparing to get new work unit...
[04:36:18] + Attempting to get work packet
[04:36:18] - Connecting to assignment server
[04:36:18] - Successful: assigned to (171.64.65.20).
[04:36:18] + News From Folding@Home: GPU folding beta
[04:36:18] Loaded queue successfully.
[04:36:20] + Closed connections
[04:36:25]
[04:36:25] + Processing work unit
[04:36:25] Core required: FahCore_10.exe
[04:36:25] Core found.
[04:36:25] Working on Unit 01 [December 11 04:36:25]
[04:36:25] + Working ...
[04:36:25]
[04:36:25] *------------------------------*
[04:36:25] Folding@Home GPU Core - Beta
[04:36:25] Version 0.10 (Mon Oct 30 12:32:17 PST 2006)
[04:36:25]
[04:36:25] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 13.10.3077 for 80x86
[04:36:25] Build host: CYGWIN_NT-5.1 vishal-gpu 1.5.19(0.150/4/2) 2006-01-20 13:28 i686 Cygwin
[04:36:25] Preparing to commence simulation
[04:36:25] - Looking at optimizations...
[04:36:25] - Created dyn
[04:36:25] - Files status OK
[04:36:25] - Expanded 86934 -> 443709 (decompressed 510.3 percent)
[04:36:25]
[04:36:25] Project: 2733 (Run 3, Clone 18, Gen 5)
[04:36:25]
[04:36:25] Assembly optimizations on if available.
[04:36:25] Entering M.D.
[04:36:31] Working on 1258 GPUlambda
[04:36:31] mdrun_gpu returned 114
[04:36:31] Going to send back what have done.
[04:36:31] logfile size: 122131
[04:36:31] - Writing 122669 bytes of core data to disk...
[04:36:31] Done: 122157 -> 37384 (compressed to 30.6 percent)
[04:36:31] ... Done.
[04:36:31]
[04:36:31] Folding@home Core Shutdown: EARLY_UNIT_END
[04:36:35] CoreStatus = 72 (114)
[04:36:35] Sending work to server
[04:36:35] + Attempting to send results
[04:36:37] + Results successfully sent
[04:36:37] Thank you for your contribution to Folding@Home.
[04:36:41] - Preparing to get new work unit...
[04:36:41] + Attempting to get work packet
[04:36:41] - Connecting to assignment server
[04:36:44] - Successful: assigned to (171.64.65.20).
[04:36:44] + News From Folding@Home: GPU folding beta
[04:36:45] Loaded queue successfully.
[04:36:46] + Closed connections
[04:36:51]
[04:36:51] + Processing work unit
[04:36:51] Core required: FahCore_10.exe
[04:36:51] Core found.
[04:36:51] Working on Unit 02 [December 11 04:36:51]
[04:36:51] + Working ...
[04:36:51]
[04:36:51] *------------------------------*
[04:36:51] Folding@Home GPU Core - Beta
[04:36:51] Version 0.10 (Mon Oct 30 12:32:17 PST 2006)
[04:36:51]
[04:36:51] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 13.10.3077 for 80x86
[04:36:51] Build host: CYGWIN_NT-5.1 vishal-gpu 1.5.19(0.150/4/2) 2006-01-20 13:28 i686 Cygwin
[04:36:51] Preparing to commence simulation
[04:36:51] - Looking at optimizations...
[04:36:51] - Created dyn
[04:36:51] - Files status OK
[04:36:51] - Expanded 86964 -> 443709 (decompressed 510.2 percent)
[04:36:51]
[04:36:51] Project: 2733 (Run 5, Clone 10, Gen 5)
[04:36:51]
[04:36:51] Assembly optimizations on if available.
[04:36:51] Entering M.D.
[04:36:58] Working on 1258 GPUlambda
[04:36:58] mdrun_gpu returned 114
[04:36:58] Going to send back what have done.
[04:36:58] logfile size: 122160
[04:36:58] - Writing 122698 bytes of core data to disk...
[04:36:58] Done: 122186 -> 37151 (compressed to 30.4 percent)
[04:36:58] ... Done.
[04:36:58]
[04:36:58] Folding@home Core Shutdown: EARLY_UNIT_END
[04:37:02] CoreStatus = 72 (114)
[04:37:02] Sending work to server
[04:37:02] + Attempting to send results
[04:37:03] + Results successfully sent
[04:37:03] Thank you for your contribution to Folding@Home.
[04:37:07] - Preparing to get new work unit...
[04:37:07] + Attempting to get work packet
[04:37:07] - Connecting to assignment server
[04:37:08] - Successful: assigned to (171.64.65.20).
[04:37:08] + News From Folding@Home: GPU folding beta
[04:37:08] Loaded queue successfully.
[04:37:09] + Closed connections
[04:37:14]
[04:37:14] + Processing work unit
[04:37:14] Core required: FahCore_10.exe
[04:37:14] Core found.
[04:37:14] Working on Unit 03 [December 11 04:37:14]
[04:37:14] + Working ...
[04:37:15]
[04:37:15] *------------------------------*
[04:37:15] Folding@Home GPU Core - Beta
[04:37:15] Version 0.10 (Mon Oct 30 12:32:17 PST 2006)
[04:37:15]
[04:37:15] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 13.10.3077 for 80x86
[04:37:15] Build host: CYGWIN_NT-5.1 vishal-gpu 1.5.19(0.150/4/2) 2006-01-20 13:28 i686 Cygwin
[04:37:15] Preparing to commence simulation
[04:37:15] - Looking at optimizations...
[04:37:15] - Created dyn
[04:37:15] - Files status OK
[04:37:15] - Expanded 86892 -> 443709 (decompressed 510.6 percent)
[04:37:15]
[04:37:15] Project: 2733 (Run 5, Clone 12, Gen 3)
[04:37:15]
[04:37:15] Assembly optimizations on if available.
[04:37:15] Entering M.D.
[04:37:21] Working on 1258 GPUlambda
[04:37:21] mdrun_gpu returned 114
[04:37:21] Going to send back what have done.
[04:37:21] logfile size: 122535
[04:37:21] - Writing 123073 bytes of core data to disk...
[04:37:21] Done: 122561 -> 37345 (compressed to 30.4 percent)
[04:37:21] ... Done.
[04:37:21]
[04:37:21] Folding@home Core Shutdown: EARLY_UNIT_END
[04:37:25] CoreStatus = 72 (114)
[04:37:25] Sending work to server
[04:37:25] + Attempting to send results
[04:37:30] + Results successfully sent
[04:37:30] Thank you for your contribution to Folding@Home.
[04:37:34] - Preparing to get new work unit...
[04:37:34] + Attempting to get work packet
[04:37:34] - Connecting to assignment server
[04:37:35] - Successful: assigned to (171.65.103.159).
[04:37:35] + News From Folding@Home: GPU folding beta
[04:37:35] Loaded queue successfully.
[04:38:06] + Closed connections
[04:38:11]
[04:38:11] + Processing work unit
[04:38:11] Core required: FahCore_10.exe
[04:38:11] Core found.
[04:38:11] Working on Unit 04 [December 11 04:38:11]
[04:38:11] + Working ...
[04:38:11]
[04:38:11] *------------------------------*
[04:38:11] Folding@Home GPU Core - Beta
[04:38:11] Version 0.10 (Mon Oct 30 12:32:17 PST 2006)
[04:38:11]
[04:38:11] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 13.10.3077 for 80x86
[04:38:11] Build host: CYGWIN_NT-5.1 vishal-gpu 1.5.19(0.150/4/2) 2006-01-20 13:28 i686 Cygwin
[04:38:11] Preparing to commence simulation
[04:38:11] - Looking at optimizations...
[04:38:11] - Created dyn
[04:38:11] - Files status OK
[04:38:11] - Expanded 87051 -> 443705 (decompressed 509.7 percent)
[04:38:11]
[04:38:11] Project: 2711 (Run 1, Clone 109, Gen 4)
[04:38:11]
[04:38:11] Assembly optimizations on if available.
[04:38:11] Entering M.D.
[04:38:18] Working on Protein
[04:38:43] mdrun_gpu returned 114
[04:38:43] Going to send back what have done.
[04:38:43] logfile size: 122757
[04:38:43] - Writing 123295 bytes of core data to disk...
[04:38:43] Done: 122783 -> 38384 (compressed to 31.2 percent)
[04:38:43] ... Done.
[04:38:43]
[04:38:43] Folding@home Core Shutdown: EARLY_UNIT_END
[04:38:44] CoreStatus = 72 (114)
[04:38:44] Sending work to server
[04:38:44] + Attempting to send results
[04:38:46] + Results successfully sent
[04:38:46] Thank you for your contribution to Folding@Home.
Folding@Home Client Shutdown.
i just put my x1900xt in different box and am getting something similar :|
I have a hunch it may be the PSU or voltages in my new box... will report on results later
check your card voltages with atitool
I had done that, and created a profile just for folding where the voltages were correct, but I forgot to make it my default. Ooops! 😱
Well, I've gotten as far as "completed 1" now, so I think its actually working!
We'll see soon enough, but hopefully this thread can at last be put to rest!
Thanks to all for your suggestions, especially CupCak3 and GLeeM!
Looking forward to (at least) doubling my PPD, go teAm!
It was our GPU guru, CupCak3, that helped! I was taking stabs in the dark as I haven't run this thing yet although I hope to soon.
Just remember that there are quite a few WUs that will EUE just because 😕 so don't get discouraged if a few do.
Wow, so the default voltages on your card were incorrect out of the box? Is that something that can be fixed with a bios reflash?
how do i set up so i can run 1 instance on cpu and one on gpu? i keep getting the "already f@h running" box with the gui install of the cpu version
I think I read somewhere that you need to have one CPU available to run with the GPU. So, you can't run two instances unless you have a dual core CPU..
-Sid
I"m glad we could help Cuhulainn 🙂
bob4432: you need to set one client with a machine ID of "1" and the other client with a machine ID of "2"
do i need the command line version of the cpu version? i just set the gpu one to machine id 2 and still got the box. anything else i need to change in the cfg file?
quick update,
i d/l the command client, moved over the cfg file and data file info and work folder into a folder called folding cpu, then moved all the info for the gpu one into a folder called folding gpu. made the gpu machine id 2, cpu one id 1 and both are working now. then put a short to each one on the desktop. seems the gpu one takes quite a bit out of computing, and just out of curiosity, why is it using so many cpu cycles? i thought it worked on the gpu, but if i have it to 100% it will utilize 1 core by itself. i have to run the cpu one at 90% and the gpu one @ 75% or else the machine is very sluggish.
just out of curiosity, how do i see how far along the command line one is?
thanks in advance,
bob
The current GPU client takes a lot of CPU time, but the F@H scoring reflects this. For now, GPU systems earn about 660 points per day while the GPU client is in beta instead of 440.
