Eyefinity with an Asus EAH5870
Let us know what you find out.. mine did it just running the screensaver after 2 hours..
I'm going to run SC2 tonight and check what clocks are when it happens. Then try to increase/decrease clocks manually and see if anything happens. Maybe we can come up with a theory on the cause.
Good call, CJ.
It happened last night, but only briefly. I didn't have enough time to check. Will have to keep CCC open. Sigh 🙂
I didn't get a chance, Wife pulled aggro on me, however I am off work today and plan on playing alot of WoW today so I will let you know.
Well it happened again yesterday during my day off. I even shut down for about 30 mins then changed the wiring making the DP the left monitor and it still did it..
If you are using 10.12 drivers, roll back NOW. Uninstall the current drivers, download and install 10.10e hotfix from AMD's website.
Its usually the 3rd week of every month.
Ok. Good. but I will try the rollback this weekend.. I closed the AC vent in the man cave and its freezing cold, which is good for the PC. my idle temps dropped down ateast 3-4 degrees, I've seen idle temps get as low as 26c..
Im there now, btw, whats the difference between the 10.10e hotfix and the actual 10.10 CCC?
The actual 10.10 is WHQL certified. Generally, 3rd party vendors submit drivers to Microsoft.. for them to test internally. It usually takes a couple of weeks(rough estimate) for MS to validate that drivers. These hotfix's are released to fix bugs and/or include optimizations without WHQL certification.
10.10e hotfix driver, although released before 10.11, is actually a successor of 10.11.
Well I gave 10.10e a shot. I played WoW for like an hour then played Black OPs multi player. Stopped and brought up a browser to search the web. it started flickering again, but this time it flickered on all monitors.
I would pull the browswer to the left and right, use the mouse wheel to scroll up and down the page and the content flickered. This only happened with the middle monitor on 10.12.. strange.... I do not understand......😕😕😕
Updtate, AMD has 2 flavors of 10.12
1. AMD Catalyst 10.12 Preview for Windows 7– Featuring the new Catalyst Control Center
2. Catalyst Software Suite (64 bit) English Only
its seems that my temps run lower with No 2 than No 1. however the issue still exists with the middle display, but takes longer with No 2 driver installed.. weird..
