I pulled the original Seagate C drive and replaced it in the case with the cloned Toshiba since that's working for boot, then moved the DVD drives back to the ICH10R ports, so all six current devices are on the Intel controller.
Disconnected all USB devices but the KB & mouse and boot time is now under 3 minutes to responsive. However, from 40 seconds until 2 minutes, it's going to sleep still. It's POSTING so fast that the screen hasn't turned on before it's already into detecting drives, then Windows boots and then at the 38-40 second mark, zzzzzzzzzzzz. Then around 2 minutes, it wakes up and finishes loading.
What is it doing there? We could be looking at a 1:45 cold boot time if not for the nap. (Plus whatever lag happens when the external USBs are hooked back up.
EDIT: For grins, I uninstalled my nVidia drivers and swept with Driver Cleaner. On the subsequent boot, the mouse cursor appeared at the 40 second mark along with the "Welcome to Windows" splash - Yay?!? - and then the background went black, leaving the cursor on the screen for a long time while Windows doddered around trying to find the drivers. I manually ran the install and the subsequent boot was longer, if anything than before. I still haven't reconnected any other USBs.
I've manually set the BIOS to go for PCIe-1 16X. For the longest time, it was just set to PCI, though I don't think that should be the issue. I've double-checked in the manual that the card is in the correct slot.
