Originally posted by: TBSN
...so If I buy a mobo with a 4pin cpu fan header, will a normal 3pin fan fit in the socket?
I don't care what it does, the fan just needs to spin to cool the cpu. After that I can worry about speed adjustments, etc.
If you just want it spinning, then you just need to apply a 12V power to the fan. Unfortunately 3 pin connectors do not connect into four pin connectors. So you have to rig a little connection yourself.
1. Take little pieces of wires (about the same gauge as the ones came on your fan), and connect the appropriate pins from the 3 pin connector to 4 pin connectors. It's extremely straightforward (+12 to +12, Gnd to Gnd, Sensor to Sensor). Note that if you don't care about the fan speed reading in BIOS, that sensor to sensor connection is not necessary.
Here's a tip on how to make this connection: If you have a old power supply somewhere that you can salvage for parts, find the floppy connector on it. It is a four pin connector. You need to file down the little notch so that it will fit in the 4 pin fan header on your MOBO. Then connector the wires and plug in!
2. If you don't have any motherboard fan headers available, you can always use the 4 pin molex connector on your power supply (I hope you have one of those available
). The 4 pin molex connector has +5 GnD GnD +12. So you only need to connect +12 to +12 and Gnd to one Gnd. If you don't want to do this yourself, you can go to microcenter and they have this conversion available commericially for 2 bucks or so (not worth it in my opinion since it's just 2 pieces of wire).
These two ways will get your fan running. Alternatively, you can buy a fan controller (Newegg has a few, compusa has a voltage based one really cheap, and so on). Then just plug the fan into that. Those will have 3 pin headers so your 3 pin fans will fit.
Hope this helps. Just remember, all you need to do to make a fan run is to apply 12 volts (actually anything above 5 will probably do it) to the fan.
