extreme budget build ~600
narreth
519
Will the Antec Earthwatts 430 be able to hand all of this?
Rosewill R5604-BK Case $50
8800GT $240
Western Digital 250Gb HDD $70
antec earthwatt 430W $55
GSKILL 2Gb $47
GIGABYTE GA-73VM-S2 $59
E2180 $83
Is there anything you would change on this build? How many years should it last before I have to upgrade?
narreth
519
homefully gaming >_>
will the E2180 bottleneck the 8800gt?
is the E4300 a better deal?
MarcVenice
Moderator Emeritus <br>
Apr 2, 2007
5,664
The PSU will be fine. The CPU should be okay too, for some games it will be better to have it running at 2.4-2.8ghz though. Which is a really easy to achieve, even on the stock cooler.
narreth
519
will 4GB make sense to put the extra ~50 out for? or is 2Gb fine?
Also, would the E2180 OC well with that cheap mobo?
MarcVenice
Apr 2, 2007
5,664
accguy9009
504
10
Here is the way I would go for your budget build and overclock since it is so easy
http://www.clubit.com/product_...il.cfm?itemno=A1938263
http://www.clubit.com/product_...il.cfm?itemno=A4830813
Use promo code EBL2171938263
Should be $ 161.47 shipped ( unless you live in Cali)
Same parts shipped from the Egg are $ 178.82
Not sure about this but would this be a better deal on the Power Supply since the deals on the Earthwatts have expired?
http://www.newegg.com/Product/...x?Item=N82E16817103940
sutahz
1,300
If you can, add on a $15-20 cooler. Wost case its only as good as that tiny HSF intel gives you, best case it helps you OC .5-1.2Ghz more
VirtualLarry
56,587
10,225
Check the hot deals forum for a Rosewill 775 cooler for $18 shipped. Looks decent.
