External USB2 Hard Drive Enclosures
live4spd
112
I have 2 of these external enclosures...
http://www.newegg.com/Product/Product.asp?Item=N82E16817173003
Now I can't get either of them to function with a Hitach 500GB hard drive. Is there some sort of storage limit with the external enclosures? One person reviewing the product said he used a 400GB Seagate.
FYi I know the 500Gb drive is good I tried it in a PC, also both enclosures work with a Maxtor 120GB drive.
Any ideas?
Operandi
Sounds like a limitation of the chipset in the enclosure. Probably due to the capacity of the drive or something else about the Hitachi.
AmberClad
4,914
All of the ones I saw while shopping around for mine only support up to 300 GB. The only one I know of that does support 500 GB is sold at Best Buy, the brand starts with an "A" (Adaptec???).
TRUMPHENT
1,414
Rosewill and Newegg both left out that little detail. The one about how large a drive you can use.
Amberclad was correct, the brand she saw at BestBuy was Adaptec.
Go here to get the appropriate part numbers.
Adaptec USB/Firewire enclosures!
live4spd
112
Well Rosewill emailed me back and they said it only supports 400Gb. BUT I set the drive to "slave" installed it int the enclosure and it works fine. I've been copying data back and forth for several hours now.
madthumbs
Banned
Oct 1, 2000
2,680
The earlier ones I believe had a limit of ~137GB just like the early xbox bios's, and earlier mobo's bioses before LBA patches.. just checked the link and it's for Rosewill. I'm using Bytecc which is much cheaper and the later ones for those support LBA.
