external tv tuner
vcv1122
9
Does an external usb tv tuner have the ability to see a broadcast signal using an antenna?
If so, which one's are recommended? I'm trying to use a laptop for tv in an area with no cable. Thanks in advance.
Bruiser1
Mar 19, 2003
18,289
I would imagine so...if it has a regular coaxial input (to which you would connect the antenna), of course.
xtknight
12,974
yes i have an ati tv wonder usb2.0, and it works very nice. tv quality is very good. i use it for cable because it looks a lot better than my crap tv wonder VE PCI card.
ShadowBlade
4,263
ive got a pinnacle pctv vision pci card.....works great unless i try to use my x-box with it (dont know why)
homercles337
6,340
Originally posted by: Insidious
Hauppauge makes a nice USB tuner
See it here
~ $130 USD
-Sid
edit: You can set it up for Air (antenna) or cable/satelite
Yep. Been using mine for both broadcast (in grad school) and cable for 6+ years. :)
