Hey guys. So right now I have a Macbook Pro and a PC that I built (runs Windows 7, but the PC was built in 2008 or something?)
I'm a DJ/music producer and I used to just use my PC for DJ-related stuff like storing and editing tracks that I use for DJing while using my Macbook for music production. Well, my PC is getting really finnicky. I think I need to reinstall or repair Windows, but my friend in NYC has the Windows disc I used. I think I would rather just go to using my Macbook anyway so if I get an external and transfer the data from my PC there, then I can just put my PC in the closet.
I've been doing research and I was going to get a Seagate 4TB Expansion HD for around $125...BUT I saw some reviews saying it isn't a good drive to use if you plan on having it on a lot because it doesn't have great cooling. Do you guys recommend anything different? Going by reviews Seagate seems to have better reviews than other companies, but I am a bit concerned.
Also I was told that I should format the new HD with my Mac first and then get this program for my PC so I can transfer data to the new HD and have it compatible with the Mac - http://www.paragon-software.com/home/hfs-windows/
Does that sound right to you guys?
