I've got a 160 GB SATA running INSIDE a Shuttle SB61G2 with Windows XP (SP2) no problem.
I took a WD 250 GB, changed the jumper configuration to Master from Cable, put a in an extremepcgear ME-720 external case. When I hook it to a USB 2.0 port, it is only recognized as 128 GB when I try to partition.
Doesn't the support of the 160 SATA mean everything is OK inside the computer? I think the external has a Prolific chip set, could that be the problem?
