BW86
- Jul 20, 2004
- 13,114
- 30
- 91
Don't use torque wrenches to break stuff free!
You need leverage? This is leverage.
Yes, we broke a breaker bar.
Twice.
rofl, I used a bar like that to break my axle bolt free
Twice.
This
From what I know it's called a cheater bar
i just don't see how toyota really thinks that tiny short wrench they give you in the trunk would work. you'd literally have to hammer it with something else on a stubborn nut. maybe they think you'd smack it with the tire jack![]()
Twice.
You're applying more torque than the engine does with a bar that long lol.Don't use torque wrenches to break stuff free!
Twice.
anti seize... hm
wonder why that isn't standard procedure, or is there a reason...
anti seize... hm
Because the anti-seize will screw up your torque reading.
The use of anti seize compound when not called for in the factory manual lessens rotational torque and increases longitudinal stress. If your manual does not call for anti seize compound, then don't use it.
I can't tell you how many lug nuts and oil plugs I've seen that came off just fine, and when I put them back on, the threads were destroyed and felt as though they were cross-threading, but that isn't what happened.....and I've also seen many that started to go on okay, but the threads came apart as I gunned it the rest of the way on.....not the fault of anyone, just happens.
I would only do it with a short headed wrench, not an X like that one. With the X you're not only twisting the nut but also bending the lug downward.
Lugs nuts questionably, but oil plug? I hope you're not using a pneumatic wrench, much less an impact on oil plugs. And if you're using one on lug nuts, getting them off easy isn't a big concern of yours either. Lug torque specs aren't really that tight, I don't see the big problem with just using a torque wrench and doing it right. Hammering them on with an impact is going to be the biggest contributing factor to stretching and killing the threads.
You need to kick the ass of the tire shop. Wait untill they strip one of the heads off a lug that was overtightened and then want to charge YOU extra to get it off.
Better idea. But yourself a $20 torque wrench from Harbor Frieght and check the lugs at random when they work on your tires. If they're over torque, walk right back up front and tell them to do it right.
It's the difference between static and dynamic torque (and if they even set their impact guns for a specific torque). Pay attention to whether they bother changing anything between cars. If not, they're using the same amount of torque to put a F-250 super-duty duelly tire on as they are a Fiesta sub compact. Bad.
