E works like an antidepressant, tho obviously a lot more dangerous...
it blocks the reuptake of serotonin in your brain...so your brain cells are releasing the serotonin into the synapse (small space between brain cells), but it stays there...causing this happy relaxed feeling....some antidepressants prescribed by doctors work the same way...
all 5 senses will be increased like 110%...that's why if you've ever been to a rave or similar type party, you'll see ppl giving/getting lightshows, massages, stand against the speakers, etc....
if your gonna be a user of it, my suggestion would be to keep at least a month between drops...cuz once you drop, all your serotonin is gone and it takes a long time for your brain to build back those levels...granted chances are it will never be at the same level as before cuz some of your cells will be fried...word is your best roll will be your first time, which makes sense cuz your serotonin levels will be stored up at their highest...
do it too frequently and you'll need to take more for the same affect, bear in mind it will never be like your first time cuz your serotonin levels will never be the same...and your brain will be fried...hence the term E-tard....loss of memory, reading something the wrong way, etc...similar to what you see in long term ganja users...
what i've seen some ppl do is do a sort of "preloading" before dropping....sort of a preparation to help minimize the negative effects of E...they take 5-HTP, which they say is a precursor to serotonin, helps the brain to make more of it...they also take Vitamin C to help counteract some of the negative affects, i've also heard that vitamin C works as sort of a catalyst for E...enhancing its effects...
and finally..as many have already stated, always drink water....obviously don't drink alcohol, it'll just dehydrate you more and increase your risk of total dehydration....
