Originally posted by: Jeff7181
... until you start raiding. Hunters who hit autoshot and go take a piss are horrible, horrible Hunters. It takes skill and awareness to really play a Hunter effectively in raids and even groups. There's a Hunter in my guild I'd rather have with me for CC than most Mages.
Jeff, I believe he's talking about leveling here, not raiding and such. He's also correct, when it comes to simple grinding quest mobs and such, a hunter can be fairly easy and literally you can just turn autoshoot on and go make a sammich.
Again... Mages who die often are very crappily played Mages. Part of being a DPS class is being able to control your DPS, and that's really the only reason a Mage should accidently die in a group. Soloing with a Mage is no different than any other class... they have ways to deal with an accidental add, and sometimes all it takes is one add to kill you, as with every class.
Yet again, we're talking about leveling. You won't always have a tank for you and have you tried playing a mage when you're fighting in a cave? I can't even count how many times I died in the Wendigo cave in Dun Morogh near Kharanos... fortunately I wised up pretty quickly and just killed mobs on the outskirts of the cave
Originally posted by: QuantumPion
Warrior: easy to get the hang of, but not very interesting
It is good to note that if you play a warrior first, you'll usually be alright, but if you play a warrior after a rogue, you may end up getting annoyed at how much easier rogues are and how much harder things can be in a pinch situation or how much easier 1v2 is on a rogue. You'll learn that fighting green mobs is much easier than yellow
Priest: somewhat difficult until you get face melting, at which point they are powerful but boring.
True, eventually you get to the point where you can walk away from your PC and be just fine. I did it plenty of times while leveling my priest... came back to my priest, mob dead.. full health and mana.
Rogue: fun all around, you can stealth, do good damage, and try out different combos and stuns
Probably one of the top classes to play. Even for a new player, they offer a lot without having to know some of the tricks of the class. They also provide an exit (Vanish, Blind, Sprint) if you make a mistake.
Hunter: The most boring class of all once you get your pet, just sit there and autoshoot. Very easy to play however.
Well this depends on what you do... on my Hunter, I prefer fighting mobs that are orange or red con just to see if I can do it. This kind of goes back to my talk about challenging myself rather than going ezmode.
Paladin: more of an advanced class, for beginners are also fairly boring.
Well, it's really that you don't need to do much to succeed. You're a warrior with a little bit less damage who can heal himself. You also have great survivability, but not on par with a rogue.
Warlock: Very powerful class, once you learn some advanced techniques. Can be boring similar to a priest if you don't challenge yourself.
It is also good to note that they are practically the kings of soloing; along with hunters, there's very little they cannot solo.
Shaman: Similar to warlocks, in that they can be fun if you use advanced techniques but are boring otherwise.
Shamans really give a giggle when you get huge Windfury crits
Druid: a varied class that gives you lots of options to try out, but at low levels aren't very powerful.
Definitely the issue... at low levels (which is what we're looking at) the druid won't be as powerful as other classes.
