What do the auto makers say about fluid changes? General Motors and Chrysler do not mention brake fluid in their
scheduled maintenance recommendations. A General Motors spokesman saidDelco Supreme 11 DOT 3 brake fluid
contains additives than many other brake fluids do not, so it is essentially a lifetime fluid. Starting in 1993, GM beganSo GM does not consider fluid contamination to be a significant problem.
using a new type of rubber brake hose with an EPM lining and outer jacketing that reduces moisture penetration by 50%.
Being a GM tech, that is what I went by-others recomennend replacing-But I still think you are a deuche bag.
See my brakes call for that supreme #11 deco fluid and yeah It could be a lifetime fluid......iiiiffff you never had to add or do a damn thing to the brakes the whole life of the truck.. Haha it's lifetime of ur braking system lasts the life of the car, I get it as in the additives don't break down as fast normal fluid, but saying lifetime a joke! What if I replaced my calipers and need to add more brake fluid to my system.... Can I add your standard dot 3 you get from any store or do I have to use the delco? Would I have to completely drained all out delco and swap it to cheaper fluid? Do u think it's safe to add standard to my delco #11?
