Exchange 2010 Install - EMC Initialization Failed
stlcardinals
729
You can try anything you want. I'm just saying from a professional's viewpoint, I would not run what you currently have in a production environment after the problems you have had. I would start over.
It seems like you do not have much experience with Exchange. You should probably have done a test run in a lab enviornment to at least go through the installation process.
pollardhimself
281
Yeah i know now thats its done! im going to try a manual uninstall
pollardhimself
281
Do you have any other Exchange servers?
Yes I have one on our sbs2003. Im probably going to just reformat and start from scratch.
Is this the correct steps
1. powershell
Import-Module ServerManager
Add-WindowsFeature NET-Framework,RSAT-ADDS,Web-Server,
Web-Basic-Auth,Web-Windows-Auth,Web-Metabase,Web-Net-Ext,
Web-Lgcy-Mgmt-Console,WAS-Process-Model,RSAT-Web-Server,
Web-ISAPI-Ext,Web-Digest-Auth,Web-Dyn-Compression,NET-
HTTP-Activation,RPC-Over-HTTP-Proxy -Restart
2. cmd prompt
setup /prepareSchema
3. Install Exchange?
I got 2 videos showing 2 different things
http://www.youtube.com/watch?v=M7svA539Ey0
http://www.youtube.com/watch?v=3g-QlQpNdUA
or should i just use this
How to install Exchange 2010 prerequisites automatically
http://www.exchangemaster.net/index.php?option=com_content&task=view&id=98&Itemid=57
stlcardinals
729
Those steps look fine. The schema prep has to be done since you do not have a current Exchange 2007 server. Exchange 2007 and 2010 use the same schema additions.
rasczak
10,437
23
remember, it usually takes a couple of reloads for you to get things just right. Just remember to document your steps as well and what worked and what failed for future reference.
pollardhimself
281
You dont have to run those commands Something else is wrong
JRVA_Q
Vote As Helpful
Just curious, what made you think you needed to reinstall in the first place? Setup will run all those prereq commands for you (look in the setup logs).
