Everybody upgrade to Firefox 3.6 now....
0roo0roo
64,795
84
Do you know your extensions don't work? You can disable compatibility checking, and most will work fine.
yea but if it aint broke....
i remember the awesome bar thing they did last time. now they messed with the tab order. i just don't feel the rush to upgrade unless its a security update anymore.
lxskllr
60,100
10,567
Pedantic? They load practically instantly and disappear a fraction of a second after that. Like it actually impacts the browsing experience? Hardly.
It affects the experience big time, you're still waiting on laggy adservers. That's the only reason I block ads. I don't care if they're on the page, but I don't want to wait for them to load.
pcslookout
11,959
157
Firefox can get bent with it's memory leaks, etc. I'm moving to Chrome.
Chrome has just as many of those problems. Just try loading up a lot of tabs and coming back to them you will see. It is not just a firefox problem. Firefox handles it the best out of the two.
lxskllr
60,100
10,567
Tab order you can fix in about:config. That was one of the first things I changed. I like my tabs loading at the end of the list.
Nik
16,101
Add their domain to your hosts file. Bam, done.
SSSnail
17,458
83
86
Isn't Chrome just a thinly veiled IE? Because I swear the last time I went to Chrome's Options, it took me to IE's Options...
lxskllr
60,100
10,567
No, it's built from the ground up. I'm not sure what was going on in your case.
Zee
5,171
chrome will never support adblock preemptively the way firefox does. ads are google's bread and butter
Fayd
7,970
www.manwhoring.com
adblock + noscript user here.
also, if i'm browsing something that i think might be shady, i pop over to a VM of linux.
(alright, no i dont.. i keep that open just for bash shell)
Gibson486
18,378
That virus has been around for a while.....The people that actually download it....man....it is a sob to remove.
Gibson486
18,378
Yeah, it is its own browser, but it does use the same settings as IE. If you make a change in IE's settings for proxy and stuff, the changes will also apply to Chrome.
Codewiz
5,758
Open Chrome, go to Options > Proxy > be :awe:
Chrome builds on the OS settings. Just like Chrome on Mac, it will use the proxy settings that are set by the operating system.
Why recreate what is already available from a settings point of view. Chrome also uses the Microsoft certificate stores on Windows.
It is one thing that pisses me off about Firefox. You have to maintain two different certificate stores. Two different network settings. It is duplicate work. Chrome uses what is already available. If it needs more then it goes above and beyond it when needed.
Codewiz
5,758
While correct for Chrome, Chrome is built from Chromium. Chromium is open source so it could be done as a fork
Fritzo
41,920
2,161
I'll pass... Chrome still has a ways to go on its adblocking extensions. The blocking of the ads after they are loaded is highly annoying... I like my pages to load as if the ads were never there to begin with.... And not look all fucked up and shit. Ugh, it's so annoying. >_<
Wow, it's amazing how sensitive people are to ads. I've never used an ad blocker and just learned to filter advertisements out. I don't even see them anymore. Seems like people spend way too much energy trying to filter out something harmless.
Fritzo
41,920
2,161
He's saying that when you open network options in Chrome, it takes you to Internet Options. Internet Options is NOT Internet Explorer- it's Window's network settings.
