Hello,
I ordered my setup from Newegg last night and was wondering how the people with the Evercase cases are setting up their fans? The $42 case w/ the side case fan was OOS so I just ordered the case and side fan separately. I also ordered a Enermax 80mm fan as well.
According to the Manafacturer's website, you can put a fan in the front, back and side. I figured I can put the extra fan up front and then use the side fan to exhaust but I am not sure how good the front will work since I don't see where there are any holes up front.
Any tips on this case fan setup?
Thanks
Thanks
