Ever accidentally put gas in a diesel or diesel in a gas?
Locut0s
This happened to us tonight. Were in a hurry and my father must have grabbed the wrong nozzle, a few hours latter and the car won't start.
Originally posted by: SynthDude2001
Nope. I thought the nozzles were of different sizes so you couldn't put diesel in a regular gasoline tank? Or am I mistaken?
That's what I thought, however it turns out that you can. Or at least maybe sometimes you can. I know that you can't do this with leaded and unleaded gas.
Its true to an extent. Mosr diesel nozzles are larger to facilitate a higher flow rate to fill semi tanks. We're talkin 200 gallons here, not the 20 in your Accord.
However, some nozzles are designed for passenger vehicles (Same size as gas) to make it eaiser to fill up your car or truck. So, if your at a station that uses the car sized diesel nozzles then they are the same size as the gas nozzles. Also, if your at a pump with gas and diesel on the same island, your almost assured of having the same sized nozzles for both.
Exactly the case here. Island had 2 gas and 1 diesel. They weren't extremely carefully labelled either you'd think they'd paint the diesel one a different colour or something.
The handles are usually different colored, black for gas and green for diesel. Same for storage cans. Gas is red, green is diesel, blue is water.
It might be law or code to have the nozzles colored. If the nozzles werent colored I would look into it as a possible misrepresentation or some such, however if the nozzles are black and green for gas and diesel then your dad is just a dumbass.
classic canadian thing! j/ik
We were in a hurry/
We were in a hurry/
I understand that. Hence my telling you you might want to check to see if the nozzles were colored correctly. If they arent, you *might* have a legal leg to stand on.
If they are, then hurry or not, well........ If the shoe fits.......
They are different.
Not always.
Maybe not but all that I have seen are. At least he didn't put gas in a diesel engine. Much worse off that way.
Wont hurt the engine, but it might damage the o2 sensor. Drain the fuel, change the filter, cross your fingers. If it still wont start the plugs might be fouled and need cleaning/replacing. I am a heavy equipment mechanic and this happens often at my work.
Pretty much sums it up. Doesnt hurt anything, just makes a big mess. Call Mr. Clean.
yea ur prolly ganna have to drain the fuel tank, change the fuel filter and change the plugs as diesel burns very dirty and everything prolly has a residue over it
I almost did once. I didn't realize their were two nozzles and grabbed the one closest to me at the moment. I noticed that it was green, thought that odd, then noticed the black one on the other side of the pump. It was one of those stations where you have to push the button for the type you want, so I would have eventually noticed it, when nothing came out of the nozzle. I felt really stupid that day. 🙂
: ) Amanda
Originally posted by: zip1385
ROFL. I have no idea how someone could do that even in a hurry. I even own a diesel truck and a gas car.
Me too, I always check it twice as the diesel car is the company car, which would mean my ass getting fired.
Funny, I own a diesel car and gas truck..... 😕
